Question about Argox OS-204 Thermal Label Printer
Argox printer os214
I am facing a problem that it prints one label and escapes 4 to 5 labels without printing and the lights of the printer starts blinking any solution to these problems
    Problem Solver:
  • 5 Answers
Possible prpblems
1. your design need ribbon but your ribbon not installed
2. your label label gab type set but your design set continous type label
3.may be your calibration fail. You can calibration with one key.
best regards
Ufuk
Posted on Apr 02, 2009
How can i print?
Go to the Argox web site does your model printer do labels? check the media spec's. Are using the correct setting in the print driver? Check the printer setting on the machine. web site mite have a work around also might go to web site down load up grade driver to allow ding lables
Oct 16, 2015 | Argox OS-214 Label Printer
Printer Command using VFP
Greetings
Install Bartender software,seagul printer driver.
Design your label.
Print the label to file.
Use the file to embed in vfp (increment the variable i.e. the one printing 18...)
Buzz me at 9344104232, mmi.mdu@gmail.com
M. Murali
Feb 10, 2015 | Argox Office Equipment & Supplies
When I print a label I have to press the feed button to get the label out. How do I get it to push out the entire label without me having to feed and reset the whole time?
Most people I know print addresses from a sheet of labels, which ejects at the end. It sounds like you are printing one address from a continuous roll of labels, and they are so close together that the printer cannot push it out for you without misaligning the next one. I think both systems are designed mainly to print a batch of labels at one time.
If you are printing a batch, it is best to prepare the whole set first and save it as 'data' for printing addresses. For a one off or just a few I would use a sheet of 24 labels (say) with 3 to a row, and 8 rows.
Does this help?
Jan 06, 2014 | Argox OS-214 Label Printer
When I print a label it print ok but the roll scroll one page and the light blinks.
It sounds to me like the label size is wrong, or more likely that the page size is wrong. Check the label settings. Make sure it doesn't have something like a separator page or maybe needs another label page behind it.
Oct 18, 2013 | Argox A200 Printer
Needs to be restarted after every print command
You can always try a tailor made driver for free at www.nicelabel.cl ( you will need to enter your data), that's how we solve ss.ss. bad drivers issues for our customers
Oct 16, 2012 | Argox R-400 Thermal Printer
Where do i buy ARGOX GE-200 PLUS
Argox launched Ethernet industrial label printer
Adopted Ethernet management makes industrial printer strengthened
Argox adopted Ethernet into industrial printer series and launched X-2300E(203dpi) for regular resolution printing and X-3200E(300dpi) for high-resolution printing to meet different demands. Both X-2300E and X-3200E are equipped with enlarged memory - 8MB Flash Memory/16MB DRAM- leading ahead of competitors. The built-in RTC(real-time clock) is also an advantage to work alone with the printer to print time/date on the label without a PC.
X-2300E/X-3200E provides PPLA/PPLB/PPLZ(X-2300ZE, X-3200ZE) emulations for all application. And the auto calibration function supports 4 modes of setup provides flexibility for the users to choose the most convenient mode for different printing applications to ensure accurate label detection.
To satisfy the requirements of industrial printer application like wide area between operation systems in network and large number of equipment, utilizing Ethernet to deliver printing tasks is a more economical choice for enterprises. X-2300E/X-3200E installed Ethernet server to provide the interface of Ethernet data transfer and by using SNMP setup to deliver the error massage back to managing server to simplify the procedure and enhance efficiency.
X-2300E/X-3200E supports Windows 7 system and 1D barcode, 2D barcode, QRcode and etc. It's suitable for the production line of manufacture including safety labels, patent labels, and?parts-name stickers, and fit for the application of shelf-label printing management, storage, delivery, shipping, transportation, luggage labels and wash care labels for clothing.
LINK IS GIVEN BELOW..................
http://www.argox.com/content.php?sno=0000486
GOOD LUCK......................
Sep 22, 2011 | Argox OS-214 Label Printer
We have argox thermal barcode printer....the issue is while printing for example printing 10 copies it leaves space i.e it prints 4 copies and leaves a space and again print 4 copies and so on .... please...
Hello santiago271 ,
Hopefully problem might occur with the printer calibration setting, try printer calibration in argox printer,
if that does not work, check the label mm/inch setting.
if that do does not work, check the labels peel gap in between is even.
Hope fully, this should solve your problem
If you Any other queries, Related to barcode printer - Sales and Services.
Contact , Trridev Labelss Mfg Co Leading Labels Convertors In Tamil nadu
For more information visit our web page.
Aug 05, 2010 | Argox R-400 Thermal Printer
Need label file
Hello Mr.balamurugan
I think you are asking about printer consumables. Like Barcode Labels or Pre-Printed ones.
First thing, you need to buy the labels from the direct labels manufacutures and avoid buying from the resellers.
We have some common sizes like 50 x 25 or for little big labels like 100 x 50 .
Rates vary depending on the volume,
if you have not purchased the printers, i recommend you to take a look at these printers.
Zebra TLP 2844 - [Click To Preview Brochure] Citizen 621z - [Click To Preview Brochure]
If you require the quote for labels printer or labels. please contact us, or provide us your contact no. so that our sales men can reach you.
Kirubakaran Trridev Labelss Mfg Co www.trridevlabelss.com Mobile 96000 07995 Email : Kirubakaran.rv@gmail.com
Dec 03, 2008 | Argox OS-314 Label Printer
Argox OS-204 Thermal Label Printer Logo
596 people viewed this question
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
sahoo_sanjay
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
