Question about British Telecom Synergy 2110 Cordless Phone
BT Synergy 3505 LCD Display failing!
Help! Both my Mum & I have the above phones, we have it with answerphone & additional handset, and she has 3 handsets. We have had the phones for about 4 years, and are really happy with them. owever, in the last few months we have both noticed that the LCD display is failing - and we can't read who is calling! Neither of us have replaced the batteries, and were wondering if this is the problem. However, my mum phoned the BT helpline yesterday and was told by one person that she simply needed new batteries, and then when she phoned back to order them was told that new batteries won't solve the problem, and the phone is just old. Please help!
  • jackie816 Oct 19, 2008
    The same thing has happened to one of my handsets. Even with new batteries, there is nothing on the display, it doesn't beep when it's put on the base station, and it doesn't work.
3 Suggested Answers
SOURCE: set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Posted on Oct 28, 2008
SOURCE: base unit on bt synergy 3505 keeps beeping and
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Posted on Apr 05, 2010
I have changed the batteries on a Synergy 6500 handset but it does not charge and the display is blank. What could be the problem?
No actual idea, but check user manual, go to BT website and check there (esp FAQs). Do BT have a customer helpline?
May 16, 2015 | BT Synergy 6500 Cordless Phone - DECT -...
BT SYNERGY 5500 HANDSET IN TEST MODE
Having changed the batteries on my bt synergy 5500 trio it now displays that it is in test mode. How can I activate my phone so that I can receive and make calls
Oct 02, 2012 | Lands Phones
Additional handset on BT Synergy 6500 phone is stuck on 'Test Mode'
is possble to use 8 bt 6500 hand phones via 2 base unit on the one bt line
Feb 28, 2012 | GE 25942GE2 Cordless Phone System
Base unit on bt synergy 3505 keeps beeping and handset keeps displaying base 1 and losing signal.... intermitent fault....have changed batteries in handset and switched unit on and off but still not...
Jul 20, 2009 | British Telecom Synergy 2110 Cordless...
I have a bt synergy 2110 cordless phone. There are 3 lights on the right hand side. one for power/in use, one for charging one for new call . All3 are lit up. How do i get the "new call " light to go out...
I may have a solution you can try.
1. Take handset out of cradle.
2. Press and hold bottom, right hand side, bottom button, marked "Calls"
3. Hold until "Display" shows number of calls, usually 10 and makes a bleep-type noise.
4. Now press top left button, marked "Del" in red, until the display scrolls through all 10 numbers and deletes all the numbers stored in the memory. The phone should then make a bleep noise.
5. Press "red handset symbol" (finish call) twice.
6. Replace handset onto cradle and the "new call light" should go out.
You should now be able to make calls.
Good luck !!!
Nov 27, 2008 | British Telecom Synergy 2110 Cordless...
Set time and date on bt synergy 3505
hope this helps.
Sep 26, 2008 | British Telecom Synergy 2110 Cordless...
BT Synergy 3505
Hold down the forward skip button on the answer machine, it will say 3, if you have it set to 3 rings, just press the forward skip button again to the required number of rings, 10 being the max. Thats it job done.
Jul 20, 2008 | Lands Phones
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
British Telecom Synergy 2110 Cordless Phone Logo
66 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
David Burbee
David Burbee
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
