Question about Neff Refrigerators
My neff side by side fridge freezer has 2 twist knobs in the fridge next to the ice cube making switch. they are numbered from 1-7 when the freezer was empty i had the freezer set to 4 and fridge to 4 since the freezer was filled yesterday i turned the setting to 7 and over night the freezer has started to defrost, is 7 the coldest or 1? thanks
  • piggyonahog Sep 03, 2008
    thanks for that. fan is running lights are on but defrosting set on number 7 any ideas? thanks
    President:
  • 1,462 Answers
7 is the coldest and 1 is the warmest
Posted on Sep 03, 2008
Check if compressor is running as well. if compressor is very hot to touch then indicates compressor fault or possibly short of gas. also if compressor clicks every few minutes, indicates compressor fault as well./
Ice maker is not dropping ice
there are 2 things that could be problem, 1 is a heater element that heats the bottom of frozen cubes slightly to allow the cubes to be pushed out into the tray by plastic fingers under the cubes and controlled by a motor. best bet would be to get model number of fridge and/or ice maker and look for direct replacement online. There is a company out of Chicago that offers replacements for lots of models. Sorry I dont have their name, but google the results for ice maker for your make/model fridge.
Jan 28, 2013 | Refrigerators
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Neff K3990 American style fridge ice maker is not producing ice
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Neff american fridge freezer, ice dispenser
Are your ice cubes to big or in the dispenser door not opening all the way both can be fixed adjust the flow timer on the ice maker or replace the door dispenser
Jul 27, 2008 | Neff K3965XO Side by Side Refrigerator
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Ice Maker Making Noise
I was able to solve this problem by doing the following:
1) Carefully (because there may be sharp metal blades in this area) reached into the upper left compartment of the icemaker and pressed down on ice cubes that seemed to be lodged there and were protruding slightly above the slots they should have been passing through.
2) Press down on the cubes, forcing them through the slots and into the cube container below
3) Lift the metal arm, remove and completely empty the ice cube container
4) Return the ice cube container to the freezer, making sure it is seated properly
Close the freezer and wait until the ice cube maker begins to make new ice cubes. The sound should stop in around 10-15minutes.
Nov 06, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
435 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
