Question about EliteGroup ECS 755-A2 Motherboard
Motherboard 755-a2 hi, i need manual to motherboard 755-a2. i'd like change my BIOS . my SATA can't see DVD . help please Gregory
I go Why can't I install Windows XP on my S-ATA HDD by SiS964? A: You have to copy the driver paired with the motherboard package into a floppy disc before you installing WinXP or Windows 2000 on your system, and follow the notice showed on the screen to insert the floopy disc. The system will grab the needed driver from the disc to finish the installation of S-ATA HDD automatically.
Because SiS964 was announced before than Windows XP and WinXP therefore it can't recognize it. If you want to install a whole new WinXP (or Windows 2000) on S-ATA HDD by SiS964, you need to copy the necessary driver from the directory named floopy image on your driver CD to one floopy disc. When you begin to install OS, follows the instruction to put your disc into floopy drive. After this, you will keep on installing your WinXP smoothly. If you use P-ATA HDD, you don't need to do like this.
t this off the sis.com web site what does it all mean.
Posted on Oct 17, 2008
  • 51 Answers
The manual is at the ecs web site. Go to google and do a search for ecs 755-a2 manual and follow the link for the ecs website.
Posted on Jun 07, 2009
Dell Optiplex 755 - 2 sata ports (2&3) not working on motherboard. They have been switched to "on" in the bios, but will not recognize sata HDD or sata DVD. Only ports 1 & 2 are working, so I now have a...
hi There.
this is all i could find out from the internet so not sure if this will help you out.
(I went into BIOs again after I looked the SATA port over on the motherboard. The SATA ports on the motherboard are listed as 0,1,4,&5. In BIOS the SATA ports are 0.1.2.3.4. & 5. I have been trying to turn on 2 or 3 as they are the next ports and never tried 4 or 5.
When I turned on 4 and 5 everything is working fine.
Why do they list SATA ports 2 and 3 when they are not present on the motherboard)
or see if this link helps you.
Dell Optiplex 755 2 sata ports 2 3 not working on motherboard Google Search
Dec 15, 2017 | Computers & Internet
I bought "GH22NS50 22X Internal
Have you tried going into your control panel and used the Add Hardware wizard? Hopefully, that is all it will take to fix the problem. Otherwise, I would probably use your 1 year limited warranty letting them know that your Windows XP would not recognize the drive.
Jun 05, 2011 | Computers & Internet
Where can I fine manual for 755-A2 I went to EliteGroup www. No luck. Can you please HELP. Thank You
Try this:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=381&DetailName=Feature&MenuID=1&LanID=0
Sep 26, 2010 | EliteGroup ECS 755-A2 Motherboard
Cannot find the SATA hard drives for my ecs 915PL-A2 mother board. All connections have been checked
Did it just stop? Or is the a new system?
Did you check your BIOS settings?
ECS is not known for excellent quality - if you have a bad board hopefully it is still under warranty.
Mar 04, 2010 | EliteGroup (ECS 915PL-A2) Motherboard
Epox motherboard and SATA disk
According to the hard drive manufacturer Maxtor, motherboard host controllers using the VIA and SIS chipsets VT8237, VT8237R, VT6420, VT6421L, SIS760, SIS964 found on the ECS 755-A2 manufactured in 2003, do not support SATA 3 Gbit/s drives. To address interoperability problems, the largest hard drive manufacturer, Seagate/Maxtor, has added a user-accessible jumper-switch known as the Force 150, to switch between 150 MB/s and 300 MB/s operation.[9] Users with a SATA 1.5 Gbit/s motherboard with one of the listed chipsets should either buy an ordinary SATA 1.5 Gbit/s hard disk, buy a SATA 3 Gbit/s hard disk with the user-accessible jumper, or buy a PCI or PCI-E card to add full SATA 3 Gbit/s capability and compatibility. Western Digital uses a jumper setting called "OPT1 Enabled" to force 150 MB/s data transfer speed. OPT1 is used by putting the jumper on pins 5 & 6. http://en.wikipedia.org/wiki/Serial_ATA
Dalius
Mar 30, 2009 | EPoX EP-8K9A7I Motherboard
ECS 755-A2 won't go past BIOS Screen
do you have the setup cd that came with the board. the drivers probably need to be installed. if so run the disk and install the drivers and it will work.
Mar 13, 2009 | EliteGroup ECS 755-A2 Motherboard
POST-Beep-Code List availible for Phoenix-BIOS? ECS 755-A2
The problem is with your RAM. Try installing the RAM in another slot. Install your AGP card slowly. I can assure about your motherboard yet you have no problem without assembling. Keep informing.
Feb 22, 2009 | EliteGroup SiS755 (755-A2 V1.0)...
ECS 755-A2 USB 2.0 no working
The best thing to do is uninstall the USB drivers on the machine and download off ECS the latest firmware and install.
Jan 07, 2009 | EliteGroup ECS 755-A2 Motherboard
Motherboard
Well you really need to get a manual for that. Check the website and download the manual with that model, for sure there is one.
I guess you have connected all the connectors there incorrectly so better look for a manual.
Dec 09, 2007 | EliteGroup ECS 755-A2 Motherboard
EliteGroup ECS 755-A2 Motherboard Logo
406 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
