Question about Acer Aspire 5610-4648 Notebook
USB Drive Not working
I have Acer Aspire 5570Z with Vista as the operating system. I am not able to use any memory key on my system. In device manager it comes up with yellow exclamation mark. Tred copying inf files from 1386 but tere are no such files. I do not have OS cd and am not able to find any compatible chipset drivers for my system. Please help
Try to format your laptop again. install all appropriate drivers. different kinds of laptop models have varies of driver. good luck!!
Posted on Sep 13, 2008
How to format a maxtor one touch III on aspire m3201 acer computer using vista
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Aug 01, 2012 | Seagate Maxtor One Touch III 750 GB USB 20...
How to do system recovery on aspire one
Hi you should be able to do the following, if not you will need an external CD drive & recovery disk.
1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
Warning:
It is possible to delete the hard drive partition that has the recovery tool.
If your Acer Aspire One no longer has the recovery partition, you will need
to acquire an external USB DVD drive and then contact Acer for a recovery DVD.
Connect the USB drive to the netbook's USB port and then insert the recovery DVD in the drive.
Hope this helps.
Feb 14, 2011 | Acer Computers & Internet
Upon startup before anything else happens (except asking me if I want to press f2 for setup) my aspire one netbook says: For Atheros PCIE Ethernet Controller... v1.0.0.5(1/22/09) check cable...
This means you should install an Operating System.
If your notebook doesn't have a dvd drive you can install the Operating System with an external drive (dvd, USB flash drive or hard drive). and press F12 when it starts to select the booting device.
Follow the link below to find out how to create a USB flash drive bootable (also works on hard drives):
http://forum.bstdownload.com/how/55-how-create-bootable-usb-stick-when-using-windows-vista-windows-7-a.html
Feb 01, 2011 | Acer Aspire One PC Notebook
How to reset myacer to manufact setting
Nov 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
I reinstalled my vista and dont have drivers to my acer aspire 5570z . the sticker on the notebook says 5570 2609
The following website contains all drivers that you require:
http://gd.panam.acer.com/home/
Click on
Notebook
Aspire
5570z
Select your operating system from the drop-down box
Jul 04, 2009 | Computers & Internet
I can't use my Acer laptop touchpad an more.
If you are using vista than
Use a usb mouse to do this.
  1. Right click 'my computer'
  2. select ' device manager'
  3. locate you touchpad and select it and right click and choose 'update driver software'.
If you are using xp than follow steps 1 and 2 and the third step is 'unistall' than click scan for new hardware. XP should see the touchpad and update the drivers for it.
Jan 02, 2009 | Acer Computers & Internet
After installing vista service pack 1 my dvd rom is gone.
I would try stopping the device and restarting it first.
If that doesn't work, find the latest drivers for it, and have them in a folder you can find easily. In device manager, you can right click, go into properties for the DVD-ROM. Click the update drivers button, and point it to that directory.
If neither of those work ,try completely uninstalling it from device manager, then going through the add new hardware option in control panel.
Dec 03, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer 5100 lost dvd/cd drive
Is the DVD drive listed in device manager under CD/DVD drives at all? If so, remove it and reboot. Windows might be able to re-detect and reinstall the drivers for it, but odds are the drive is bad. You can try removing the drive from the computer, and use compressed air to blow out the area where it connects to the laptop. Also check the connection on the DVD drive to make sure there isn't any physical damage, bent pins, etc.
Hope this helps - remember to rate!
Sep 30, 2008 | Acer Aspire 5100 Notebook
Download the latest driver for dvd rom from Acer that will work with Vista SP1. Also try uninstalling the device in device manager and restart your computer. Vista may find "new hardware" and install the driver from its driver pack in SP1.
Jul 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5610-4648 Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
