Question about Asrock P4i65GV Motherboard
About mother board
Why the my personal comp is restarting
Need it
Posted on Oct 12, 2008
The power went out of My place last night... I woke up and my Mother board was flashing orange... I tried to restart my computer. Nothing happened can somebody help me? It is a Dell computer
Steps:
1. Unplug all the cables from the computer. (If you are not sure then make a note of which cable goes where)
2. After you've unplugged the cables. Press and hold the power button on your computer for about 3-5 secs.
3. It wont start the comp :). This steps is done remove any left over power in the comp...
4. Re-connect all cables and check.
Let me know if this helps, If not, then i'll tell you what to do next. :)
Also, please let me know if you use Dial or ADSL Internet. Because if previous steps dont work then we need to try anther steps.
Dec 21, 2012 | Computers & Internet
My computer screen went blank and now it won't turn off or restart
reset the bios by removing the watch battery on the mother board then short the two contacts, reinsert the battery, plug the comp. back in and hopefully that will fix it
Oct 10, 2010 | Computers & Internet
Hello, ive got a HP 5189-0466 FOXCONN MCP73M02H1 NAPA HP MOTHERBOARD. and im building just an internet comp for the downstairs for the kids but im having troubles finding the manual for it. Cant seem to...
open side panel remove cable from usb reader i have pulled CABLE AFTER install new mother board same thing stuck no key board 1 blink/ f10 got setup ..... stuck . This may be a chip set driver not installed. or a bad hardware pulling to mush power. I change CPU, MEM sticks. Power supply all the same thing. Just pull these cable to hadrware not hdd. boot right up . BINGO> c:\users\office\appdata\local\temp\msohtml1\01\clip_image001.gif down 1yr.
Jun 23, 2010 | Computers & Internet
Computer powers on, no beep, monitor is blank
open the tower, on the mother board you will find the RAM card approx 6 inches long, take out the card and restart the comp, you should get the beeping sound and the mother board is fine, if no beep that indicates the motherboard has gone bad.
place the ram card properly into the same slot and then restart the computer. NOTE while putting your hand into the comp components always make sure that the pwr cord is pulled out or else you will get shock.
also check the cord at the back of the harddrive should be fixed properly. take it out and refix it at both ends . probable cause is there is some loose connection of the cord or the RAM.
May 10, 2010 | Computers & Internet
B210 MOTHERBOARD
research the board but it usally cant really be improved that much it woud better buy a new comp
May 08, 2010 | Dell Dimension 3100 PC Desktop
When i turn my comp on the lights and fans start for about 1 or 2 secs then stops my make of comp is zoostorm
Pleease remove all connections (including Front Panel pin assignments) from Mother Board except Power Supply.
Now find out reset pin assignment on mother board and shot that pin if its woking then again do all connection and try.
other wise dismental complete system and re-assemble sytem. your problem will be solved
Mar 20, 2010 | Computers & Internet
Help with acer aspire reboot,
Sounds to me like the new motherboard is bad too
Jul 15, 2009 | Acer Aspire 5610-4648 Notebook
Problems with my mother!
PUT YOUR OLD COMP BACK THE WAY IT WAS .IF IT BOOTS AS ALWAYS,GO TO CONTROL PANEL.SELECT "SYSTEM",SELECT DEVICE MGR,SELECT DISK DRIVES.RIGHT CLICK ON YOUR SLAVE,SELECT UNINSTALL,FOLLOW INSTRUCTS.TURN OFF COMP AND REMOVE YOUR SLAVE.REBOOT.HOPE IT WORKS FOR YOU!
BUME
Mar 07, 2009 | Intel D865GLC Motherboard
One speaker not working
Left/Right balance can be adjusted in the "Sounds and Audio devices" in Control Panel. If the adjustment is not the issue then the soundcard is at fault.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Nov 14, 2008 | Harman Kardon SoundSticks Computer...
System error loading
try restarting and go to bios,set to default config.
Also,
This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP.
See this article:
http://support.microsoft.com/kb/326676
Dec 15, 2007 | ASUS P4VP-MX Motherboard
Asrock P4i65GV Motherboard Logo
51 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
