Printer will not collect paper for print or will send several pages through together. I have tried single, several,adjusting, fanning paper, cleaning printer This problem has been here since I purchased printer but would sort itself out. What am I doing wrong?
  • 3 Answers
Re-install driver. if that does not work contact manufacturer.
Posted on Sep 03, 2008
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
Why isnt my 2530 printing and the ink is full
"isn't printing" can mean several different things, each with a different cure.
If it tries to print, but no ink on paper, run a cleaning cycle and then a nozzle check.
If it just sends the paper through without trying to print on it, paper position sensor may be broken, out of adjustment, or otherwise damaged. Likely to cost more to fix than a new printer.
If it just sits there and does nothing, check self-test, print setup page. Does that work?
Jul 21, 2014 | Epson WorkForce WF-2530
Paper stucked inside
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
Paper wrinkles at bottom of page when it prints document and sometimes feeds a blank page in between pages.
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Also check the rear panel and make sure that all the guides and rollers are moveable and not distorted in any way.
Also check the paper pick up for wear as this will cause additional pages to be collected and fed through the printer. Make sure that you fan the paper before use ant it is of suitable quality and weight.
Sep 29, 2009 | HP LaserJet 4 plus Printer
More than one paper at a time
Are you saying that the printer pulls in too much paper at a time, or that it's actually printing on more than one page, even if you only want to do a single page? If it's pulling in too many pages, try fanning the paper. At times, especially in low humidity conditions, paper will tend to stick together and then several sheets get pulled into the printer. Fanning will often relieve the symptoms. Also make sure that the feed roller is clean. Use a cloth with some alcohol on it and rub the tire all the way around or as much as possible. See if that works.
Jan 28, 2009 | Canon BubbleJet i550 InkJet Printer
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Canon IP3300
clean you print que it prints all the pages because the print button was pressed several times so for to empty the print que unplug itwait 30 seconds then restart the printer if you press print more than once all the pages will print when the printer is turned on safety measure
Mar 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printing problem
Since the printer is a top feeder, meaning it feeds the paper from the top your printer is defective. Just call the company up and they'll send a refubished one. This happened to my Lexmark Printer then it also went in sideways hoe this helps. They told me to clean the wheels inside or turn it upside down and tap it a few times because it could have collected dust! Sorry if i didn't help!
Dec 13, 2007 | Epson C64 InkJet Printer
Samsung 1710 stops after warm up
Chances are, you're getting paper jams.  Try cleaning the rollers (as indicated below.)  If that seems to help the situation, then you'll need to get new feed rollers.
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Oct 29, 2007 | Samsung ML 1710 Laser Printer
43 people viewed this question
k24674
jasbo
jasbo
