Question about Bosch Washing Machines
Hi,i have a SMS6032GB dishwasher,it keeps sticking during the wash cycle & go on for ages.
I think I had the same problem on the same model of dishwasher.
It would stop part way through the cycle and finally would not even begin to fill at the start of a wash.
Turned out to be the Water Inlet Solenoid Valve. I proved this by using a jug to fill the dishwasher up to the level of the heating element - it then completed that part of the cycle successfully.
The valve wasn't too hard to change. It is under the 'kick plate' at the front of the machine. Bought a spare from ebay for £35.
I know this is a late reply, but I came across it when I was searching for a solution - but there wasn't an answer.
Posted on Mar 12, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Whistling sound
Kind of hard to tell without hearing it. Also when does it occur? During the fill portion of the cycle? During the main wash period? Or during the drain portion of the cycle? Also how old is this dishwasher?
If I had to guess (and I do, since I don't have the answers to the above questions), I would think that the bearings of the main wash motor were going bad; especially if the dishwasher is more than 7 or 8 years of age.
May 16, 2015 | Dishwashers
Why does the large reservoir in the door that holds the detergent leaks continuoulsy?
Over time old dishwasher detergent that doesn't dissolve during a wash cycle can get crusty causing the reservoir to stick or not fully shut. Also, some reservoirs use doors with a gasket seal which loses its ability to seal after many wash cycles. Some doors like this have a latch that wears and no longer latches. Not knowing specifics, it is difficult to diagnose. I had to replace my reservoir in my Frigidaire because I couldn't keep the door closed.
May 26, 2014 | Dishwashers
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
Kitchenaid Superba dishwasher getting louder in wash cycle
The bearings in the wash motor can wear and cause the machine to get louder, They can be replaced but it depends on the age of the machine if it's worth repairing or not.
Mar 08, 2012 | KitchenAid Dishwashers
My wirlpool dishwasher tab compartment don't open through the wash cycle
Clean it out with boiling water, soap residue is making it stick. The compartment is opened by heat during the wash cycle.
Dec 23, 2011 | Dishwashers
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
Du1100xtpq7 has had the touch pad replaced along with the circuit board that goes behind it and yet it just keeps repeating the wash cycle and goes for hours
i would guess that you are having a problem with the optical sensor inside the pump housing. it is suppose to sense when the water is clean or dirty and allow the unit to continue washing or advance to the next cycle.
i have seen these test good but be just out of calibration enough to cause long run times.
you can try to change it yourself or have the service company try that instead of a new board and panel.
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
LG Dishwasher LD-1403W - loud whirring noise during wash
We had same problem machine same age, had a service person in and the found that the motor was dying. LG wouldn't cover saying that it was normal wear and tear. b
Jan 01, 2010 | LG Dishwashers
Washing Machines Logo
118 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
