Just bought a beko washing machine it only has one tap do i just connect it to the cold water
    President:
  • 1,462 Answers
Yes connect to cold water
Posted on Sep 03, 2008
Why wont my beko washing machine will not fill up with water when put on a wash cycle what can the problem be
If you are able to select the program and the ON button is accepted but no water then either the water inlet tap is shut off or the water inlet valve is faulty. Need full model number to provide more information.
Sep 04, 2014 | Beko Washing Machines
Beko washing machine wme7247w showing E08
Beko Washing machine? What is that a French Model? LOL
Your water inlet valves (hot/cold) are bad and need replacing.
Jan 19, 2014 | Beko WME7247W Washing Machine
How do i connect a beko washing machine up to hot and cold pipes
What is needed is to use proper hose to connect to the respective connections of the cold and hot line pipe in your house.
Identify the connection and buy the required hose that fits to the line
Jul 04, 2012 | Beko Washing Machines
I have a beko washing machine it doesnt work when i check it i find there is no water in it after i turn it on and it cycle then it is stopd in 27 min and it doesnt work i made eveything but nothing happen...
No water fill?
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 08, 2011 | Washing Machines
Hi there, I recently bought a second hand Fisher & Paykel Pride 5.5 washing machine and we only have a cold water tap so I have attached the cold water tap and put a copper cap I got from a hardware...
HI - THE WASHER WILL BE OK WITH COLD WASH ONLY, NOTE WHEN YOU TURN THE MACHINE ON THE WATER SECTION WOULD HAVE THREE LEDS - COLD ON BOTTOM - WARM - MID & HOT - TOP MOST.
WOULD THIS BE THE CASE? IF IT BE - THEN SELECT COLD ONLY & SHOULD WORK FINE - THERE IS A WAY TO CHANGE THE DEFAULT TO COLD WASH ONLY BUT WE NEED TO SEE IF IT WORKS FIRST BEFORE WE GO THER - IF THATS OK WITH YOU.
THE OTHER THING IS WHEN THE MACHINE STOPS THERE SHOULD BE SOME BEEPING FROM THE MACHINE - NOTE THEM IN ORDER FROM LEFT TO RIGHT WHICH HAS THE ONLY RED LED, WHERE THERES A LIGHT PUT 1 TYO REPRESENT IT - NO LIGHT PUT A 0, POST IT & I WILL SEE WHAT I CAN DO FOR YOU.
FYI - THE LED COLOURS - ARE GGGGGOOR WHEN ON...
Jun 20, 2011 | Fisher Paykel EcoSmart GWL15
Hot & Cold Water connection - can I connect just to cold?
Yes it may take a little longer to process a cycle but yes all new machines are cold feed only now.
Jul 22, 2009 | Beko 24 in. D3731F Free-standing...
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
Washing machine cold water not filling
Typically this indicates that you have a water inlet valve that is not opening. Replacement of this part would be ideal, and should fix the problem.
Regards
Brian
Sep 10, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
