Yes the baffles could be removed to clean them by removing the lint filter,in the top where the filter goes are 2 phillips head screws,remove them,use medium sized straight blade screwdriver and place it in the seam between the top in and front panel and pop up the top,them pivot back against the wall(dont worry it is hinged in the rear and wont fall off). You will see the drum and can remove the screws that screws that hold the baffles in place,to rotate the drum to get to each baffle rotate it by hand in a counterclockwise direction.
Gene
