R-805 BURNED OPEN THE AC FUSE OPEN FRON DIRECT SHORT
  • 8,617 Answers
I would need the model number to even begin to help you with the problem. Please respond to this same post
Posted on Sep 03, 2008
Why ac fuse going burn every few second on chevrolet 2007 uplander and ac not working when i try to on ac its start but coolling fan not working and after few second fuse goes burn.
You have a short somewhere causing a severe power draw. When you say cooling fan do you mean the radiator fan or AC blower fan ?
Jun 19, 2015 | 2007 Chevrolet Uplander
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
Kenwood kdc car stereo lost power when changing car battery
CHECK THE FUSE PANEL ON THE FUSES CHECK THE ACCESORIES THAT ITS THE ONE THAT CONTROLS THE RADIO OR IN SOME CARS HAS A FUSE APART IF THE FUSE ITS OK MAKE A DIRECT CONNECTION THE CABLE RED AND YELLOW FRON THE STEREO CONEC TO A POSITIVE CONECCION LIKE THE CIGARRETE LIGHTER ETC TO MEKE SURE THAT THE CAR RADIO IT DIDNT BURN
Nov 01, 2013 | Car Audio & Video
My haier tv model no. hl42e wont come on
Hello
If its power indicator LED at the front panel is also do not light up, there is some fault with its power regulator board inside it. Open your tV, and locate the power regulator board. It is easy to locate as, AC power goes direct to it after ON/OFF switch. Check the protector fuse [a glass cartridge type will be used] is burned out or not. If it ahs burned out, replace it with same type in both size and ampere capacity. You can not is rating on its rims; or it will be markde on the printed circuit board itself, under the fuse holder.
If the newly inserted fuse also blow out as soon as you switch ON the Tv, never use anymore fuses, as there is some direct short circuit with that power regulator board. It is better to replace that boad as card basis, than making any "surgery" to it. OK.
Oct 11, 2011 | Haier HL42E LCD TV
Does not power up at all no lights,
Try to check the fuse if not busted, the fuse is located at the main ac supply of your tv try t0 follow the ac cord and it will direct you to the power supply of your tv, it has two lines try to check or trace both lines to locate the fuse, if the fuse is only busted no burn marks try to replace with the same rating but if the fuse glass is covered with black that looks like something is burned inside dont replace it the other parts of your tv has a damage specially the regulator and the rectifier is shorted. Note before removing the back cover of your tv you should be sure that you unplug it first cause one mistake could cause serious injury. Good day and be careful.
Jul 14, 2011 | Sanyo Televison & Video
Just doesnt work any more? no power what so ever . I try to turn on manually and no power either. and its plugged in. I tried unplugging it fir about 6 min. and plugged back in and still nothing.
The problem of your tv is the power supply. First unplug your tv then open the back cover of your tv then try too locate the fuse, in order to locate the fuse try to follow the ac cord it will direct you to the main power supply the ac cord has to lines connected to the main pcb, try to trace each line then you will see the fuse. but there are different types of fuse, the common fuse is the glass type and the ceramic type. If your fuse is the glass type try to observe the filament inside or a small wire if totally burned do not just replace it, this mean that your unit has a shorted part common parts are the regulator and the bridge type rectifier.But if your fuse is only broken burn mark try to replace it with the exact value or rating. And if the fuse is ceramic type you should be needing a multi meter tester try to test it using a continuity in the tester. if you are not familiar with electronic parts try to consult a repairman to lessen the stress thank you and best regards.
Jul 09, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Power supply shorted out and there is only a 30 day in-store warranty . they told me to contact you directly. it shorted out our console also but we got microsoft to send us a new one.
any reason to void warranty if you opened it warranty is void ok check ac volt at power cord then open power supply check fuse if burned replace it if again blows then check bridge rectifier diodes
if faulty replace it
Oct 16, 2008 | Intel (ATX350P4) 350-Watt Power Supply
Fuse location
Good day.
Fuse is located internally. After opening the cover, Fully the lines fron your ac cord to the parts inside. You can see the fuse in there.
chris
Mar 26, 2008 | RCA D61130 TV
Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Mar 02, 2008 | Yamaha RX-V995 Receiver
Toshiba TP61E80 blows fuse
Blows AC fuse on plug-in is a direct short in power supply...
check components with ohmmeter to find short....Check MOV
across AC line by measuring across AC fuse clip.......T.
Jan 31, 2008 | Toshiba TP61G90 61" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
