The process for the passlock relearn is correct. If by chance the relearn does not work, you may have a fail component in the system. Go to this link for options to fix this yourself.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Need to reprogram the security system. turn the key to start position then to run . let the key stay on until the light stops flashing. repeat these steps 3 times then the car should start if there is not a problem with the pass-lock sensor in the ignition switch or the BCM( body control module).
