Question about Dell Inspiron 2200 Notebook
Dell blue screen error 0x0000008e
Is the bootable aviras cd a torrent that i can d/l?? pl help me!! :)..
  • deepee86 Sep 04, 2008
    thanks so much for your help!!! "I'll post here and let u know if i got it going again!!
The Avira CD I'm referring to is their Rescue CD at
I did a more detailed writeup here:
Posted on Sep 03, 2008
I have a Dell Dimesion 4500s. A black screen comes up with this Strike th eF1 key to continue, F2 to run the setup utility. I have gone thru the steps over and over again and afraid that I might do so
According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest to you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software can burn your CD/usb into a bootable one and then boot your computer from it. Run the software to fix the issue after that. There are few free software for you to use, so if you want to take this solution money is indispensable. Windows Boot Genius owns a better cost/performance among other kinds of software I've used. It may be a good choice for you if you have money to pay.
By the way,reinstall your operating system can also help you out if nothing important stores in it.
Jan 20, 2013 | Dell Dimension 4500S PC Desktop
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
I have a Asus eee 1005HA running Windows XP. When I try to boot, I get an error message saying "file missing or corrupt \windows\system32\config\system You can attempt to repair this file by starting...
download the bootable image file here, use torrent downloader to download
after download burn iso file (use burn image file) to cd, and you get windows cd installer
and you can use this cd to repair your computer
i hope this helpful
thank you for using fixya
Feb 05, 2011 | Computers & Internet
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
Aug 05, 2010 | Evesham Evolution PC Desktop
I have samsung (Model hd501hi) hard disk but it
Hi. Sounds like a problem with the harddrive boot block. Try the torubleshooting steps i provided to you below. If same issue appears after thes troubleshooting then theres a need to replace your Harddrive.
* If you have a floppy try to boot with bootdisk
if you have a bootable windows CD - try booting that then go to the repair console.
have a good one!
Jul 29, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
System is wont boot
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
May 21, 2010 | HP Pavilion dv6000z Notebook
Blue screen Dell Dimension C521
This problem occures when ther is an conflict with drivers, so try to updat your Bios from dell web site orm you may try to update the video driver or have an option to replace it and try Try to boot the system safemode and chk if you get the same BSOD if not then its the video drivers
Samson Ved
Feb 05, 2010 | Dell Dimension C521 PC Desktop
Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Oct 07, 2008 | Computers & Internet
Blue Screen
Start by pressing F2 at start up and going into the bios. The do the hard drive test, if it fails, then your hard drive has failed and will need replaced, and yes, you are going to lose your files. If the drive passes the test, then you will need to run a system repair with your recovery or operating system disc. The repair will allow you to fix the glitch in the operating system without losing any of your files.
Aug 28, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
Alun Cox
