Question about Gigabyte GA-8I845GVM-RZ Motherboard
USB drive is not working - Drivers are installed.
Hi
I m using Gigabyte GA-8I845GVM-RZ Motherboard
USB drive is not working, printer, data cable, pen drive everying is not working
but all the drivers are installed properly.
Advise please.
Arul selvan. M
  • Anonymous Dec 01, 2008
    Gigabyte GA-8I845GVM-RZ Motherboard driver download
  • Anonymous Apr 06, 2009
    my usb is not working driver properly installed but usb is not working
U have to change the southbridge processor of the said motherboard.it happens when u connect a usb device not properly in the hub and simultinously u get loss power for the computer.i.e- voltage triping , unable to controll the voltage by the ups. so u need to repair it. ---- arup karmakar tezpur , assam, india
Posted on Jun 26, 2009
  • prashshet Jan 31, 2011
    i thnk the ans is right
Hi I m using Gigabyte GA-8I845GVM-RZ Motherboard USB drive is not working, printer, data cable, pen drive everying is not working but all the drivers are installed properly. Advise please. Arul selvan. M
Posted on Feb 25, 2009
 i have the same problem
Posted on Feb 15, 2009
  • 790 Answers
Hello!!!
  Is it a new PC ?? if so guess u havent connected the USB drive slot  to motherboard. If not try other slots too.. later let me know!!
Regards, Smilemaker
Posted on Sep 03, 2008
I have a 81845gvm-rz gigabyte motherboard with internal HDD of 40GB capacity, now i am looking upgrade my internal HDD some where near 500gb is it possbile doing it. i need more free space on my c:\ drive...
The new harddrive technology you refer to is SATA.
A SATA power cable is used,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
,and a SATA Data cable is used,
http://en.wikipedia.org/wiki/SATA
To the upper right of the page shows a SATA Data cable connector, on the end of a SATA Data cable.
Below it is an example of a SATA header on the motherboard. Color does Not matter.
The SATA power cable connector has 15 pins. The SATA Data cable connector has 7 pins. Both connectors use an L shape on the inside, to line up the connection.
The type of older Harddrive technology you are using now is IDE.
It is also known as PATA.
Uses a 40-pin flat ribbon cable for the Data cable. (Note* Only 39 pins are used. One hole is blocked off, or has no wire )
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
The Gigabyte GA-81845GVM-RZ motherboard's Storage Controller Type support is IDE, [ DMA/ATA-100 (Ultra) X 2 ],
http://www.dealtime.com/Gigabyte-Gigabyte-Technology-i845GVup-to-2GB-DDRDIMM-3DDR/info?tab=specs
There are no SATA headers on the motherboard,
http://www.ebay.com/itm/Gigabyte-GA-8I845GVM-RZ-Motherboard-DHL-UPS-3-8-DAY-/390337518730?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D180645618978%26ps%3D63%26clkid%3D5166955561701266148
HOWEVER,....all is not lost. You can install a SATA Adapter Card in an unused PCI (White long slot), and use a SATA harddrive.
Example of a SATA Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329305&CatId=1455
With the above SATA Adapter Card model, you will have 4 internal SATA headers. They are on the adapter card.
[ Also advise maxing out the Ram Memory, and using the best Intel Pentium 4, Socket 478 processor, that you can obtain.
The CPU Support Chart is available on the Gigabyte Support main page]
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 26, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
I NEED AUDIO DRIVERS FOR 8I845GVM-RZ Motherboard
Hello, you can download the drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=1767&dl=1#dl
Select your windows version and download the realtek driver.
You may need to unzip the file before installation.
Oct 06, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
Hi all, i m having- G 81845GVM-rz mother board can anyone please give me all driver, i m not able to find it on google and also gigabyte site plz help urgent......?
Perhaps it's because you think the i in GA-8I845GVM-RZ is a One. (1)
GA- 8 - 'eye' - 845GVM-RZ
(Capital I)
Gigabyte Support > GA-8I845GVM-RZ main support page,
http://www.gigabyte.com/search/search.aspx?kw=GA-8I845GVM-775+%28rev.+1.0%29
Click on the Downloads (1) tab.
Now click on the Driver tab.
To the right of the - Choose Your OS - box, click on the blue down arrow.
Now click on the Operating System you are using.
Audio - RealTek AC '97
To the far right click on the country nearest yours.
Regards,
joecoolvette
Jul 16, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
My system is this type:Gigabyte GA-8I845GVM-RZ Motherboard I am install win xp load and other software pc is ok after install software install vga driver and pc restart countinuebut without vga...
One possible cause of this problem is that you have not installed the correct driver for your graphics adapter. Use the Main board utility driver pack together with your motherboard, use the auto run setup to make sure you have installed the right driver.
Let me know for any clarification.
Jun 22, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
USB port not sensing after reinstalling windows xp, drivers are installed properly. not able to use usb stick, tried to access cam with usb port, nothing is working. pls help email id :...
Check your Device Manager "Start > Run > devmgmt.msc" you may have not installed controllers for your motherboard. Look for "!" and install the drivers using your motherboard driver disk. If driver CD is not available you can download updated drivers from Gigabyte Support Site.
Hope this helps.
Jan 04, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
I need to down load sound driver foe GA-81845GVM-RZ motherboard?????????????
Driver download page for Gigabyte GA-8I845GVM-RZ,
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1767
It is G..A..8 i (Capitalized I) 845GVM-RZ
Nov 07, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Software
Just google it you should be able to download drivers for it. Most of the time you can download drivers for motherboards and graphics cards from gigabyte themselves
Jul 26, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Gigabyte GA-8I845GVM-RZ Motherboard Logo
556 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
