Question about Dell Latitude C610 Notebook
Power okay my dell latt works but now today i came home and the battery wont charge but it works fine when plugged in
    Problem Solver:
  • 18 Answers
Hi! how u doin! the problem u have is quiet common. the battery pack in your laptop is faulty. u should consider replacing it.
Posted on Sep 03, 2008
I was using my dell latitude d510 just fine the other day the only thing that was wrong is the battery wont charge so it always had to be plugged in. well from using the charger so much it finally stop...
The problem could be with the port the cord connects too. It could also be with the battery. If you take the battery out, and you still can't run on AC power, you need to replace the port. Take it to a computer/hardware shop and have it done.
Feb 24, 2011 | Dell Latitude D510 Notebook
My Dell 1525 has had ongoing problems in that it wont charge. Runs fine with the cable attached but no charging. Tried charger from another Dell with same problem. When looking in bios comes up with...
Try the battery from the other Dell system. If it charges fine, then its a problem with the battery, go for a replacement. Else, try updating the BIOS once from http://ftp.us.dell.com/bios/1525_A17.EXE. If it still doesn't charge the battery, then you may have to go for a motherboard replacement. If the system is under warranty then call Dell Tech Support @ 1-800-624-9896.
Good Luck!
-Abhishek
Apr 05, 2010 | Dell POWER SUPPLY Power Supply
Plugged in but not charging
Try removeing the battery, fire up the unit and while running, install battery.
If that does not work, have you checked out the battery.??
Oct 05, 2009 | Dell Inspiron 1525 Laptop
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
Power problems Inspirion 8600-battery not charging
Most Dell batteries have an LED indicator that allows users to see how much run time and how much overall battery life are available at the touch of a button.
To check battery charge, press the button and the number of lights that appear will tell you charge status. If all lights appear, you have a fully charged battery. Each light that appears accounts for approximately 20% charge.
To check the battery health, press and hold the status button on the battery charge gauge for at least 3 seconds. If no lights appear, the battery is in good condition and approximately more than 80 percent of its original charge capacity remains. Each light represents incremental degradation. If five lights appear, approximately less than 60 percent of the charge capacity remains, and you should consider replacing the battery
if the ac adapter will power the laptop without the battery installed its fine. if the cord is fine and your battery is fine its a mother board issue and it will most likely have to be replaced
Feb 05, 2009 | Dell Computers & Internet
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude C610 Notebook Logo
73 people viewed this question
Alun Cox
