Question about RCA HD52W58 52" TV
Curved screen and double letters
My tv has a curved screen and double picture. It had a convergence option and I have used it before and it seemed to do the trick. Now the auto-convergence option has disappeared, Am I missing something?
  • pennygraves Sep 04, 2008
    The model # is HD52W59
    there is no suffix after the model number
    Genius:
  • 1,030 Answers
If you dont have the convergence option most likely its the fl231 fuse check out the article under the tips and tricks section under my profile.
Posted on Oct 08, 2008
  • 4,234 Answers
The convergence circuit has a problem. Can you confirm the model number as HD52W58 please? I will double check the requied parts and update this.
Thanks,
Dan
Posted on Sep 03, 2008
  • ABRsvcs Sep 04, 2008
    OK. There are a few options for you. You ned to look at the model plate on the back of the set. There are variants of your model and the convergence boards are different. There may be a suffix after the model number that you posted. If not, then the convergence board is available for $9269 from tritronicsinc.com using part number 264103. If there is a suffix after the model number, please post that sufix and I'll update this with the correct part number and cost.
    Dan
    Dan
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 06, 2008 | Panasonic PT-53WX54 53" Rear Projection...
i see this alot and rca shold issue a bulliteen. so i wrote advice on this. see fl231 problem under tips and tricks under my profile. this is a simple easy inexpensive repair. if this dont help let me know.
Sep 19, 2008 | RCA HD52W59 HDTV Projection Television
Double print and curve screen
this is an indication of convergence problem. from your description the curved screen indicates complete loss of covergence. First question is in setup menu do you have the convergence option? if no then it will be the fl231 fuse problem. common to these set and if you can solder. its not a difficult repair. if you do have the option. then it can be any or all of three cuircit boards. let me know and i will do my best to see if i can help you fix it
Aug 31, 2008 | RCA HD52W58 52" TV
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W58 52" TV Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
