Question about Kenmore 24 in. 16693 Built-in Dishwasher
Will not wash
My dishwasher started making a noise like a bearing going out. today it stopped working. get water in/ pump water out. will not wash. makes a humming noise and shuts down. push cancel and water pumps out. sound like the pump and motor to you? thanks Tom
    President:
  • 1,462 Answers
Sounds like the circulating pump. could be a foreign object stuck in the pump impellor. could also be the pump capacitor - cheap part
Posted on Sep 03, 2008
Fridgeair dishwasher not working making loud sound. water comes in and I can make it drain out but washer does not start
Hello
bearings in the heater fan may get worn out or rust. If this happens, it may become very noisy, either grinding on the bearings, or scraping against the rust. If this happens you need to replace the fan motor. Sometimes, a fan blade may come loose, and you need to replace it.
Sometimes it's the motor that makes the noise you hear. The motor has bearings in it which may become worn or get rusty. When the bearings get worn, they allow the shaft to wobble which can get quite loud. If there is a spin seal leak, water may get inside the motor, washing the bearing grease away. If the spin seal is leaking, you'll notice water leaking from under the dishwasher. There is also a disc attached to the top of the motor called a slinger. It sometimes breaks off and spins around the motor's shaft while it turns, causing some noises. You will need to replace the motor if the bearings are bad. You also need to replace the motor if the slinger is broken as well.
Newer dishwashers may make a squealing or rattling noise on the first run. This is because it has not had any water in it yet, and the motor seals are dry. You may hear this in a unit that hasn't been run in a week or more as well. You should operate the dishwasher regularly to keep the sump water from getting smelly, and to keep the seals lubricated. You can add a quart of water to the sump before running it.
Rattling noises may be produced by dishes rattling inside the dishwasher due to the water pressure from the sprayer arms on the dishes. To determine if the rattling is a loading issue, run the unit empty. If the sound is persistent, it may be that there is debris in the pump.
dishwasher water-inlet valves are noted to make a hum that lasts about 60-90 seconds several times during a washing cycle. This hum is a different hum than the sound of the motor running.
A rhythmic knocking or thumping sound may be caused the sprayer arms hitting something as they go around and around. Rearrange the dishes and resume the wash.
A clunking or clanking may be heard when the detergent cup opens; while a clicking sound may be produced by the timer or electronic control panel.
A solenoid makes a snap sound when it opens. This happens about six times during each load.
Pipes rattling or banging may be caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The sound is caused by the water slamming into the closed section of pipe. A plumber can install an anti-hammer device.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and then remove the item that is making the noise or replace the pump. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher.
Send this page to your printer
Aug 06, 2011 | Dishwashers
My dishwasher is an MDBH955AWW. It was perfect
If the water pump inside is stuck, this will happen. Do not run unless you are clear. The pump coil may get burnt if left to hum.
Humming noise will be some times due to the the relay coil also. If you can check your self it's fine. Otherwise take the help of a service provider.
May 24, 2010 | Dishwashers
Leaking, now humming/grinding from motor
1)wash pump bearing damage(water leaks&leak on winding &bearing etc..,)
2)arrest the leakage &check.
Jan 09, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher makes a humming/rumbling noise when washing but stops when the water drains.
As the machine gets older, it may start to make other noises due to wear on the various parts. If the machine is working well, leave well enough alone.
Oct 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Dishwasher wont go into cycle mode and hums
No model and brand name .
the way you mention look like the main motor jammed and making the humming noise click out on overload then the humming noise stop and after a while it will humming again and continue like that until you switch off the machine. If the dishwasher is old I would recommand you buy a new one instead of changing the motor.
God Bless have a nice day Dickson
Jun 30, 2009 | Dishwashers
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
Apr 16, 2017 | Kenmore Dishwashers
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Kenmore 24 in. 16693 Built-in Dishwasher Logo
271 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
