Question about Zenith Z25X22S 25" TV
Blurry, purple cast to picture.
Mfr Date 2/1998. Sound OK, set has a full raster. Picture has a blurry, purplish cast. No burnt smell in case, removed board and looked for discolored or burned components- found none. I have no schematic and only a DMM for test equipment. Will try adjusting the focus control on the flyback but could it be the picture tube? What should I check next? Thanks In Advance. DH
  • 41 Answers
Check the crt cap that is connected to your picture tube...it may be greenish inside...try to change the crt...and adjust the focus...
Posted on Sep 03, 2008
I have sound and picture, but picture is blurry (out of focus) as soon as you turn on tv.
your crt socket problem change it but make sure it is same type it must be ok really
Jun 30, 2009 | Zenith B32A24Z 32" TV
Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that problem.sony has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
May 13, 2009 | Sony Televison & Video
Yellowish monitor display
You have no blue gun transmission. Check your work around the tube and make sure you have good connections. Ohterwise it's in the blue gun circuitry.
Feb 13, 2009 | Toshiba 36A40 36" TV
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Television - blurry
if you know to adjust the focus at the back of the plyback,the upper knob adjust it .if there's no effect, change the CRT socket,the white socket with many pins at the back of the picture tube
Oct 11, 2008 | Philips Televison & Video
Samsung Projection HDTV BLURRY!
Each projection set has focus controls in back, usually they don't move or go out of focus unless someone moves it, but in your case if you open the back you will see a focus block with 6 knobs 3 are for screen,I would highly recommend that you don't move this. Look for the focus and you will have to set each with the one color. Cover the other two and adjust.
Sep 07, 2007 | Toshiba 36A40 36" TV
NO PICTURE
do you see anything on screen.no picture doesnt mean no raster ,raster mean anything that comes out in display.no raster with sound only mean failure in either,connection in heater which means, loose connection or some new sets declare failure in vertical circuit.so be more specific ok?
May 08, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Out of focus
How old is the set? If picture is really very blurry, Try adjusting 'focus'. You can find this conttrol generally at the rear of the set. Otherwise,. if you know solid state electronics, Check the Focus control on the FBT. It is also possible that the CTR Base is faulty. Replacing this helps.
Mar 31, 2007 | Zenith Z25X22S 25" TV
Blurry picture
I Just had the same problem with my Sony KP43HT20, was a blury picture with the red & green going bad.......My set had defective convergence IC's, they are known to go in Sony's..IC's run about $30 a piece. Good Luck.
Nov 26, 2006 | Sony KP-53HS10 TV
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
78 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
