Question about AT&T Sony Ericsson W580i Cell Phone - White
W580i won't turn on or charge
I've had mine for not even a week now. First day I had it keys started cracking..didn' mind the battery went i went to charge wont charge wont turn on..
    Brigadier General:
  • 7,752 Answers
Take the phone back and have it replaced.
Posted on Oct 25, 2008
Casio G'zOne will not start or charge
Need more details. If the phone appears to turn on (you can hear or feel it do the startup sound or vibration), then the cable between the lower and upper halves might have broke. If the screen is broken or the case cracked, then it has been run over one time too many. If you have a second battery, try it with that. Some phones do not power on without a working battery, even if plugged in to charge. If that doesn't do it, then the mainboard is broke. It is waaaaaaay past time to get a new phone.
Aug 06, 2014 | Casio G''zOne Type S Cellular Phone
Van wont start
This evening, turn on the headlights. If the lights do not come on or are dim, it's likely the battery isn't charged. If the headlights get dimmer when you turn on the A/C or fan on high, then it's likely the battery is not charged well enough. That means either the battery is dead or the alternator is not charging the battery. I presume it is brutually cold (well below freezing) where you are. Test the battery with a voltmeter. 12V is the norm when the car is off. If car is below 12 V, then hook battery up to a charger for several hours or overnight, preferably with the battery in a warm place. If you can get battery voltage back to 12V by charging it, battery is fine and alternator may be bad. When car is running and alternator is working, you should get 15V; othewrwise, alternator is probably bad.
Jan 30, 2014 | Daihatsu Cars & Trucks
Cadillac battery charge
Make sure cable connection are clean baking soda & vinegar
Dec 25, 2017 | Cadillac SRX Cars & Trucks
Tablet making weird noise
you might have a deffective battery, which is a very common problem to tabs... especially if your using a generic tablet....
Jun 25, 2013 | Wacom Intuos3 6x11 Tablet PC
Yamaha YBR Custom 125 won't start after sitting idle for 4 weeks. Blockage in fuel pipe?
Fuel does "go off" but it won't happen in just 4 weeks. But, the battery will lose some of its charge in that time. Charge the battery and try again. Good luck.
Jun 19, 2013 | 2007 Yamaha Ybr 125
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
Dec 19, 2017 | Chevrolet Cobalt Cars & Trucks
Just bought a John Deere d140 had it delivered by home depot. Went to turn key, tractor completely dead. Lights won't even turn on. Looked in manual says to charge battery. What do I use to charge this...
are you pressing down the clutch/brake pedal? is the pto switch turned on?are you sitting on the seat?the lights only come on while its running not with the key turned on
Apr 30, 2012 | John Deere Garden
My '95 Oldsmobile Achieva is not starting!
have battery and relays tested --leaning toward battery fault
Apr 13, 2017 | 1995 Oldsmobile Achieva
Turn signals and brake lights not working one time neither worked at all and my battery was draining down. I can test for continuity between my positive battery post and the frame with...
I had a similar problem with a Ford Ranger. check the Main harness bulkhead connection at the firewall for looseness and corrosion. Then check the backside of the fuse block for loose connections at the affected fuse positions. The brake light switch needs to be adjusted at the pedal to affect brake light staying off when you take your foot off the pedal. This circuit is hot regardless of key switch position. Brake light switch adjustment done incorrectly can kill the battery.
Feb 28, 2017 | Cars & Trucks
AT&T Sony Ericsson W580i Cell Phone - White Logo
214 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
