Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Sirena espresso maker knob internal shaft seems loose,doesn,t always shut off in the off position. I had to unplug it to make the steam shut off,then replug it in.
  • kabee Sep 06, 2008
    Water comes out of the steam nozzle while pulling shots???? The knob is closed all the way (at least externally it is) Tried shutting off. Didn't use for a couple of days then retried with same problem. Saeco calls back while I am at work. . . very frustrating.
  • 29 Answers
Http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
try this page for troubleshooting and the manual
Posted on Feb 27, 2009
Sirena Espresso Machine powers on but will not heat up and water not priming
After weeks of trial and error, I have found the solution, to prime the Starbucks Sirena Saeco Espresso Machine (woohoo!!!!!!!!!! ). You do not need to disassemble this machine, it will not heat unless it is prim WARNING: machine must be STONE COLD before attempting this! 1. Get a large syringe (Without a needle of course, I used a 60ml one I bought at a pharmacy for $3.) 2. Fill the water tank full 3. Pull off chrome tip on the steam wand to expose the black plastic jet where steam comes out. 4. Place the tip of the syringe onto the tip of the black plastic steam jet on the machine. 5. Push the power button ON. 6. Turn the steam knob clockwise all the way until the pump starts. 7. Press the syringe onto the jet firmly to seal the connection, and simultaneously draw the plunger out. 8. Quickly, release the seal and eject the air in the syringe out (into open air not into the machine) 9. Repeat steps 7&8 until water draws into the syringe. 10. Go make yourself a cup of coffee and celebrate that you overcame the flaw in this machines design that renders most of them to the rubbish heap.
Jul 12, 2015 | Saeco Starbucks Sirena Espresso Machine
My sirena has blue blinking water light even though it has a full amount of water
Turn on the machine and turn the steam knob all the way on. Let it run until the light goes off. This primes the pump. It should run properly after that.
Oct 01, 2011 | Saeco Starbucks Sirena Espresso Machine
The steam wand seems to be clogged,how do you
Use a paperclip to make sure all the holes are clear.
Apr 14, 2010 | Saeco Starbucks Sirena Espresso Machine
The hot water steam knob on my Sirena espresso machine no longer engages to prime or steam. It just turns and turns and turns....
I had the same problem. Here is how you fix it.
There are screws behind the water tank. Once these 4 screws are taken out, you can take off the top heat plate of the sirena. Then there are more screws holding down the outerlining from which the heat plate rests on. Take these screws out so that you can take out the outer lining. This will give you full access to the part you need to work on.
Once the machine is open you will need a small allen wrench to tighten the specific part that has come loose. It attached to the axle from which the knob is attached to. Its a metal part that resembles this picture at this link
http://www.rceasy.com/wp-content/uploads/2008/08/servo_arms.jpg
On this part there is a small screw that needs to be tightened so that it controls how far the knob can turn. When this part spins along with the axle, it will hit a stationary metal block that keeps it from turning too far. You will have to mess with the mechanics of it to figure out what I am talking about. Hope this helps and good luck!
Jan 26, 2010 | Saeco Starbucks Sirena Espresso Machine
My machine will not froth milk
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 01, 2009 | Saeco Starbucks Sirena Espresso Machine
Just out of the box, the sirena espresso maker doesn't heat and buttons don't flash
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 15, 2009 | Saeco Starbucks Sirena Espresso Machine
Steam wand doesn't work
High pressure air using a blowgun?
Aug 24, 2009 | Saeco Starbucks Sirena Espresso Machine
My sirena does not work
anytime the water runs out and you need to refill the tank, you need to bleed the line so to speak. Take an empty cup and put it under the wand and open the knob of the steam wand until the blue light stops flashing
Feb 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Steam knob is stuck in "open" position
I used brute force. Remember to turn it clockwise to close.
Oct 31, 2006 | Rancilio Silvia Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
96 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
