Question about Microsoft Xbox 360 Controller
2 steady lights on a wired controller
My xbox 360 wired controller, whenever attached to a computer or xbox, only shows 2 steady green lights, at 1 and 3, and does not respond in any way...
  • 3 more comments
  • Anonymous Sep 06, 2008
    i've got the exact same problem, no button responds and the lights on 1 and 3 are showing up.
  • Anonymous Oct 06, 2008
    Even after I shutdown my XBox 360, one controller shuts off completely, the other leaves 2 green lights on faintly. Regardless of what Microsoft says, that 2nd controller deson't consume power and gives my 10 hours less play time. Microsoft needs to suply a fix or a recall for bad controllers.
  • Anonymous Jan 08, 2009
    mine is doin that too man
  • Tails_is_bet Apr 02, 2009
    same problem, it also freezes my xbox and red rings it too. But when i unplug the controller the xbox no longer red rings.
  • Anonymous Apr 27, 2009
    same
Me too. 2 steady lights on a wired controller. should we try and take it apart? i've havent found a solution online. im going to try and take it apart. wish me luck...
Posted on Apr 20, 2011
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
Tip
How to sync your Xbox 360 wireless controller
I have come across a few questions asking why a wireless controller is on but not connected, or why it is on and no corresponding green lights were on, etc.. So here it is: DRAGONF1R3 REPAIRS' GUIDE TO SYNC YOUR XBOX 360 CONTROLLER TO IT'S CONSOLE
Quite a title I know, but the actual guide is very simple.
Step 1: Power on your Xbox 360 console. In this guide I'm assuming everyone already has their console hooked up, if not, contact me.
Step 2: Power on Xbox 360 Controller. Make sure it has a battery pack that has correctly place and working batteries or charged re-chargeable battery pack.
Step 3: Locate the small circular sync button on your controller. It is near where your controller can be plugged in (between the LB and RB).
Step 4: Locate the small circular sync button on your Xbox 360 console. It is next to Memory Unit slot 2.
Step 5: Press and hold the controller sync button until the green power lights start spinning.
Step 6: While your controller lights are still spinning press and hold the console sync button. The console's lights should spin also, then flash, and finally show the player slot light on both the console and the controller.
Viola! You've synced your wireless controller! You can sync up to four controllers.
Also, you can use this guide to sync to different Xbox 360 consoles. So you can bring only your controller to your friend's house.
Note: If you sync your controller to another console, you will have to re-sync it to your own afterwords.
on Jan 18, 2010 | Video Game Consoles & Games
My controller will not link with my xbox. it just flashes 4 green lights around the circle. what can i do?
Did you sync it? here's how to sync it:
Step 1: Power on your Xbox 360 console2_bing.gif. In this guide I'm assuming everyone already has their console2_bing.gif hooked up, if not, contact me.
Step 2: Power on Xbox2_bing.gif 360 Controller. Make sure it has a battery pack that has correctly place and working batteries or charged re-chargeable battery pack.
Jan 23, 2010 | Microsoft Xbox 360 Controller
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
What happens if you press the sync button on the vbox 360 controller and the LED button lights upbut cannot get connection to the xbox 360
There could be a problem with the Controller or the RF unit on the xbox 360 console. Try another controller to make sure its not the RF receiver inside the Xbox 360. Usually when you press the Sync button on either the Xbox or the controller the lights on the X circle should spin and then flash on number 1 and stay a steady green on both the console and the controller
Nov 02, 2009 | Microsoft Xbox 360 Wireless Controller
Xbox 360 wired controller glows green for 2 secs then shuts off
Microsoft software is usually very good about finding mods within their systems. Since you have repaired a wire, it might somehow think it's been modded.
Double-check your repair work, if you used a soldering iron, it could have attached to another wire -causing a short (faking a mod). If you just twisted and taped it, you might want to consider a better fix.
Aug 01, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wired controller doesn't work
hello ill give you a tip mabey push it in harder or check the cabel are in tightly
--full str pka
Dec 31, 2008 | Video Game Consoles & Games
Xbox acting weird
Contact MS support & see what they think it could be a faulty DVD drive or a faulty box altogether.
Dec 28, 2008 | Microsoft Xbox 360 Controller
X box 360 controller
Awesome...You are THE MAN!!! WORKS GREAT
Jul 21, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
476 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
