Periodically, my contact button ceases to work. At the same time the "Contacts" item in the start menu does nothing when I clcik on it. Nothing solves this except a soft reset.
I have no clue what is causing it. It appears to be random.
Since "Contacts" on the start menu fails at the same time as the button, it is more like that there is a software problem, and the button cannot open the applet that is failing. If you want to ensure that you do not have a hardware problem, try remapping the button to open another application. You can do this by going to Settings/Buttons.
You might want to try using the Task Switcher, which you can turn on in Settings/System. When you encounter the problem with Contacts, then click on the Task Switcher and see how many programs are open. Use the Taks Switcher to close all the programs, and then try Contacts again and see if it works. Most applications do not close, and if you have many open applications, then it will degrade performance.
What do i do if my palm freezes? I tried to go into notepad and now can't get past a blank white...
(More)
What do i do if my palm freezes? I tried to go into notepad and now can't get past a blank white screen.
i can't stard my pocket PC .when I press the boutton
power this message s' post on L screen...
(More)
power this message s' post on L screen (maitenez the stylet pressed on
the target with each position on screen.la target will continue to
move jusqu' has what l' alignment is correct) .i make all its stages
but it does not start, so help
me and thank you .
