Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
My whrilpool freezer and refrigerator stop working after defrosting
Dear sir/Madam,
I noticed my freezer was leaking, so I thawed the whole freezer yesterday and clean up the system. Today, I noticed that my freezer and refrigerator did not cool the whole system. Everything is warming up. No cooling at al. But I listened to it and it seems wokring, just no cool air . What is the problem ? Lights are on , Power is on
    Guru:
  • 462 Answers
1Plugged coils (lint and dirt) cutting off air flow will cause the problem you describe; Also
2 Fan that will not run underneath the box
3 Defective compressor
4 Compressor starting components, are the 1st items that come to mind with a description like yours.
But first check your controls inside and make sure they are set to mid range.
2 types of controls in refrigerators 1 for on off and 1 for air flow. If this control you mentioned has "off" on it this is the thermostat. Look for the other one and set it to mid range
If this has helped you please rate me as high as you can and thank you for using fixya..
Posted on Apr 17, 2009
All my food thawed in my freezer. Is it just defrosting or is it broken?
Most newer freezers have self defrosting. But it will not thaw out the food at all. For it to thaw completely in 1 day, the compressor did not come on at all. I would first check the fuse or circuit breaker in your home. Many different issues could cause the same result of the freezer not getting cold at all. Defective thermostat, defective compressor, refrigerant leak or loose wiring at connection points. It could possibly be stuck in the defrost mode too.
Oct 30, 2015 | Refrigerators
Freezer not cold but refrigerator still cool
HI JULIE.TRY DEFROSTING ALL FIRST 24/48 HOURS.(USE ALTERNATIVES FOR FASTER DEFROSTING.ie;hair dryer;steamer;boiling water bowls etc.)if ok after that great.if same again then 1-defrost timer 2-defrost heater 3- t/stat.good luckALI
Jun 30, 2012 | Maytag MBB1954G Bottom Freezer...
Fridge freezer lights up but not working freezer defrosted food spoilt
dear sir/madam
i think its low refrigerant problem please contect to your service technician for refill refrigerant i n you r freezer. i hope after that your freezer will remake ice there ,
hope answer the question
thank you
please vote!
Jul 15, 2010 | Freezers
Freezer door is leaking water at the bottom of the door
This sounds like the defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle.
If you can see ice on the bottom of the freezer floor, then this is likely your problem unless your ice maker is leaking from the top of the freezer.
Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice on the food
why did you stop the ice maker? was it not working properly? was it over flowing or leaking? do you have a sheet of ice forming in the ice maker tray? if your ice maker was leaking then your water valve is not shutting off completely and could be leaking down on the food. if this is the case - you need to shut the water line off coming into the refrigerator and replace your water valve.
if it is frost that is forming on your food instead of ice then you should check to see if the refrigerator is defrosting properly. if the refrigerator is not defrosting properly you would also first notice that the refrigerator is not cold enough and then later that the food in the freezer eventually thawing.
May 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on but the rest seemed ok. Today noticed a puddle from thawed meat. Sounds like...
Good day,
Serious problem. Either there is a freon leak or a restriction inside the tubing that carries the refrigerant.
Needs the attention of a pro.
Note. If the unit is under 5 years, leave it alone. It is still under factory warranty. Call for warranty service.
May 12, 2010 | Freezers
I have a code Er dH
After taking the back out of the inside of the freezer compartment I noticed the whole coil was frozen solid. Using a hair dryer I thawed out the ice and then went to get parts. I asked for a defrost heater and the technician at the parts store felt it was more than likely a defrost heater sensor as they had been replacing quite a few for this brand LG fridge/freezer combination. I replaced the defrost heater sensor and put the unit back together. It has been 3 days now and all is working fine. Thank you FixYa for your assistance, as I am sure your guidance has saved me about $400.00. Will use your assistance in the future.
Ben
Nov 13, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
The Freezer and Refrigerator has stopped working completely
first check to see if the compressor and fan on the lower back of frig is working,if it is then check the freezer to see if the freezer fan is working,if it is then find the defrost timer(most of the time behind the front grill or inside frig. or on lower back)turn it til it clicks,wait 30 minutes and see if it comes out of defrost(you k=will know this if the freezer fan comes back on,let me know what you find-mike
Apr 16, 2009 | Refrigerators
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Leaking water
inside of freezer, take back cover out and thaw the ice with hair dryer or hot water. don't use any sharp tools. When thawed make sure water drains through defrost drain.
Jan 05, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
