Question about Westinghouse Washing Machines
Westinghouse LF652D front loader washing mashine. No power when switch is on. 240V is getting through to a Procond elettronica part (capacitor I think). Could this be broken?
jan mczeal
  • 632 Answers
SOURCE: Hi my LG 8kg top loader washing mashine says UE
UE code means an imbalance error. Either the load is too small, the appliance is tilted, laundry is gathered to one side or a non distributable things are put into the drum.
Make sure the unit is placed in level location and distribute the load evenly inside the drum. Do not load the unit with on-distributable items.
Posted on Oct 19, 2009
EllaWatson25
  • 725 Answers
SOURCE: How much water to add to Westinghouse frontloader?
If you add too much, it will just drain until it reaches the correct amount to start.
Hope this answers your questions.
Posted on Nov 17, 2009
SOURCE: I am looking for a washing mashine that looks like
i have the same problem.
did you find one?
regards from thor
Posted on Jan 25, 2010
lancaster5
  • 245 Answers
SOURCE: Kenmore top loader washing mashine
You have to replace it. Its called a lid switch. It costs around$ 45 to 50 bucks. It's really 2 screws and a plug under control panel.
Posted on Aug 23, 2010
  • 6277 Answers
SOURCE: My front loader wash mashine
Start off with balancing.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 29, 2011
Hello.i need a help,my whirlpool 6sense washing mashine 9769b when spining do horible and loud noice! I try to find bearing but i dont cnow did my washing mashine have one.
Any front-loader machine will have a shaft and two bearings supporting the tub. You may need to remove the back to find it. Also, check to make sure that whatever supports the tub (spider attached to the tub and bearing shaft) is still intact. Some models have reputations for this spider corroding and failing in as little as 2 years.
Apr 12, 2016 | Whirlpool Washing Machines
Why does my washing machine have no power
plug something else into the powerpoint to see if it works
Jul 26, 2014 | Westinghouse Washing Machines
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
Is there available any circuit diagram for an Electrolux Front Load washing machine model EW1050F cotrol PCB part number: Procond 451513103.
Pull back cover off. Get flash light and look for brown envelope that has all the
electrical information you need
Sep 27, 2011 | Electrolux EW1000i Front Load Washer
I rented a home and ive got a washing mashine(simpson esprit 450),so my poblem is how to use it.i have to put washing powder first? and where to put?then what?....pls help
Hi just read your posting.Is your machine the TOP LOADER model or the FRONT LOADER model.Please reply with additional information and I can help you with instructions on how to use the machine.
Aug 01, 2010 | Washing Machines
Nov 17, 2009 | Washing Machines
From time to time the mashine is not evacuate the water and the mashine will not start for a new load .I have to unscrew the filter,drain the water and then will wash. Is a problem with the pump? thank you...
a front loader huh, usually there is an access panel at the bottom front held on with 2 screws. remove this panel and trhere should be a trap filter that is plugged up. remove filter and clean it out, than put it back. or the water pump is going bad try the filter first.
Nov 07, 2009 | Whirlpool LHW0050PQ Front Load Washer
The washing mashine will not drain and does not spin
GO TO A APPLIANCE SHOP GET A MOTOR THEIR ABOUT20 TO 30 DOLLARS THEIR REAL EASYTAKE ABOUT10 MIN TO DOIT TO PUT IN IF ANY THING WRITE ME BACK
May 04, 2008 | Washing Machines
Washing Machines Logo
120 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
