Question about Agfa SnapScan E52 Flatbed Scanner
I have an agfa snapscan e52, it was working well on my windows xp, but no longer. I am unable to get it to co-operate. Message reads "Please connect or switch on your scanner". All cables have been checked as have. Any suggestions?
SOURCE:
SOURCE: agfa snapscan 1212; driver required for vista
2500
Posted on Dec 28, 2007
SOURCE: Driver needed to update my Agfa Snapscan 1212p to use with windows Vista
hi
I from Chile and the solution I write in Español
tienen que descargar el driver de la pagina de agfa http://static.agfa.com/digicam_scanner_drivers/
luego renombrarlo cambiando la extensión exe a zip y descomprimirlo en alguna carpeta,
colocan instalar manualmente y dan la dirección de la carpeta donde descomprimieron el archivo,
win da una alerta que el driver no esta firmado, proceden y con esto queda el driver instalado sin incompatibilidad, pueden revisar el “administrador de dispositivos”.
Para scanear, sobre el icono del scanwise, colocan propiedades (boton derecho del mouse) y en compatibilidad colocan con win95
no olviden instalar el driver para que se instale el scanwise
suerte y saludos
Posted on Dec 10, 2008
SOURCE: Driver for a agfa snapscan scaner for OS 10.5
i want driver for agfa snap scan 1212u
Posted on Dec 16, 2008
SOURCE: Agfa SnapScan 1212u Flatbed
i haven,t driver & fotolook software plzzzzzzz send to my email id.
my e-id is [email protected]
Posted on Feb 11, 2009
  • 5 Answers
SOURCE: where can i found drivers
Hello stathish,
Please download the installer from here.
http://usdn-free.nodevice.com/eb3f2500fb4129a6556214a9fcb62ca9
Run the installer and follow the installation instructions.
Posted on May 02, 2011
Where can i found drivers for windows 7 of agfa snapscan e52
Hello stathish,
May 02, 2011 | Agfa SnapScan E52 Flatbed Scanner
I want Agfa Snapscan e-25 scanner drivers for windows 7 operating system
Agfa Snapscan e-25 was introduced in the market in 2000 and discontinued on end of 2003.
The likelihood Agfa will write a Windows 7 driver is ZERO.
You may link HERE and use this XP driver on your Windows 7 machine.
Jan 30, 2011 | Office Equipment & Supplies
Quick Question. I am trying to scan something and when I go to the application to open it up this is the message I get: "The application is unable to initialize and will close." Where should I...
You don't say which type of computer and operating system you are using. However, the answer is similar, regardless of the computer you're using. You probably updated your operating system, and the Agfa software no longer works. Depending on your operating system, there are various solutions you can use. Agfa no longer supports their scanners with new drivers or updated software. That's too bad, because they made some really good scanners for years.
A common solution I'm seeing on Mac, Linux, and PC platforms is to download and install SANE files on your computer and use graphics software, a different scanner program, or a direct interface with the scanner to continue using it. I'm on a Mac, and I'm using the Scan functions in Graphic Converter 7. I understand VueScan, OmniPage, Image Capture, PhotoShop (under some circumstances), and even Word will work, if the SANE files are properly set up. What works for you will depend on your own system.
Dec 30, 2010 | Agfa SnapScan 1212u Flatbed Scanner
I have a Agfa SnapScan 1212u, but I can't find a driver to it. I have the system Windows 7
Although Agfa no longer supports their scanners with drivers and software updates, some Vista and Windows 7 users say they are still able to install the XP software and get it to run. In another thread, broccauley said: 'I got my Agfa Snapscan 1212U scanner to work fine with Windows 7. All I did was to install the XP Agfa Scanwise 2.0.0.9 software FIRST (available from Agfa website). Then I went to Devices and Printers, right-clicked on the 1212U and chose "Troubleshoot" - Windows then found and installed the driver automatically.'
Dec 15, 2010 | Agfa SnapScan 1212u Flatbed Scanner
What is the DC electrical voltage to feed a SnapScan e52, 4,5 V, 6 V, 9 V or 12 V. Many thanks for your answer
The Agfa SnapScan E50 has a 15 V, 1.2 A input, with the centre pin +ve.
Hope this helps,
Peter.
Oct 30, 2010 | Agfa SnapScan E50 Flatbed Scanner
Need driver for Snapscan 1212p for Windows XP
Look under: Installing Agfa snapscan 1212p scanner under Windows XP
You should find what you need.
Mar 27, 2008 | Agfa SnapScan 1212p Flatbed Scanner
USB Device
updated drivers.
Hot and fresh. straight from the web!
http://static.agfa.com/digicam_scanner_drivers/scanner/snapscan_e52/index.html
osX is included on the page.
Jan 26, 2008 | Agfa SnapScan E52 Flatbed Scanner
Problems with Vista.
Im sorry but your scanner is not a Certified Vista Product.
Sep 18, 2007 | Agfa SnapScan E52 Flatbed Scanner
Agfa SnapScan E52 Flatbed Scanner Logo
147 people viewed this question
Top Agfa Office Equipment & Supplies Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you an Agfa Office Equipment and Supply Expert? Answer questions, earn points and help others
