Question about Kodak Cameras
Trying to set up my camera & goofed on the setting the date/time. I pressed the ok button before after I entered the year!! How do I get back to the screen to reenter the date & time info? I have a Kodak Easy Share C813. Thank you.
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
C813
See page 26:
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 03, 2008
How Do I Reset Date/Time on a Stealth Cam STC-U732IRNG?
SET TIME AND DATE:
1. Switch the camera to the ON position.
2. Press the [MENU] button to enter menu settings screen.
3. Press the [UP] or [DN] button until the word PIR blinking.
4. Press the [OK] button to confirm.
5. Press the [UP] or [DN] button to scroll through different setting modes
until the word TIME blinking.
6. Press the [OK] button to choose the Time settings.
7. Press the [UP] or [DN] button to adjust the Minute setting and press [OK]
to confirm and move to the Hour setting.
8. Repeat to set Hour and then press [OK] to confirm and move to Date.
9. Adjust the Month, Day and Year by using [UP] or [DN] button. Each time
you finish an adjustment you must press the [OK] button to confirm and
move to the next field for adjustment.
10.Once done, the word - dEL - will be blinking.
11. Press the [MENU] button to exit and start using.
Nov 16, 2014 | Cameras
"how can i put a
Press Menu - If you see a Setup tab , press the right arrow button to highlight the Setup tab. - If you dont see a Setup tab, press down arrow button to select Setup, then press OK button. -If your camera doesn't have a Menu button, press the Review button then choose Settings.
Press the down arrow button to choose Date & Time the press OK button.
Press the Right/Left arrow buttons to move between year, month and date.
Press the Up/Down Arrow button to scroll through the year. month and date.Use the same procedure to set the Time.
When finished press OK button.
Hope this helps. Rate if it works. Thanks
May 04, 2011 | Cameras
Have never set date on my camera. What do I need to do to accomplish this? Do I needsoft ware, any cords, etc? Tried to go by instructions on line but it didn't work. What am I missing? Thanks
Welcome to FixYa,
Hi I have here the steps on how you can update the date and time of your digital camera. You can chaged it if its your first time to set the date and then you also have here the steps if you want to changed it anytime you want.
Setting the date & time, first time
The Date and Time have been reset message appears the first time you turn on
the camera or if the batteries are removed for an extended time.
1 SET DATE & TIME is highlighted. Press the OK button.
(Select Cancel to set the date and time at a later time.)
2 Go to step 4 below, Setting the date & time, anytime.
1 Turn on the camera. Press the Menu button.
2 Press to highlight Setup Menu , then press the OK button.
3 Press to highlight Date & Time , then press the OK button.
4 Press to adjust the date and time. Press to advance to the next
setting.
5 When finished, press the OK button.
6 Press the Menu button to exit the menu.
Reminders:Depending on your computer operating system, Kodak EasyShare software may let your computer update the camera clock when you connect the camera.
I hope this steps will let you to resolved your issue.
Feel free to reply on this e-mail if this steps will work or won't work.
Thank you for using FixYa.
Mar 23, 2011 | Kodak EasyShare CX7330 Digital Camera
How do I change the date on my ViviCam 5385 digital camera?
Assuming the camera is working, with the camera off, rotate the mode dial so that the icon with the wrench lines up as the active mode. Then press the Power button and turn on the camera. Press the right arrow to select Custom Menu. Then press the down arrow to select Date and Time. Then press the OK button. Use the left and right arrows to select a part of the date to change and use the up arrow to increase the value and slide the zoom lever to down button to decrease the value.Press the OK button when the date and time (24 hour clock) is properly set.
The manual for the 5385 is available at retrevo: http://www.retrevo.com/support/Vivitar-5385-Digital-Cameras-manual/id/200bh836/t/2/ . You'll need to enter a code to access the PDF.
I hope this helps.
Mar 06, 2011 | Vivitar ViviCam 5385 Digital Camera
How can I reset the camera or modify the date & time of it? Regards
Initial settings
Y
our camera's display language, date and time
should be set before taking photos or videos.
To set the date and time:
1 Turn the power on. Press the Menu button to
enter the camera's settings menu.
2 Press to select the Setup tab.
3 Press to select Simple Mode, then OK/DISP
to open the Simple Mode submenu. Set Simple
Mode to Off.
4 Press to select Date & Time, then press
OK/DISP to set the date and time.
5 Press , , , or to adjust the date and time.
When you are done, press OK/DISP.
Dec 14, 2010 | Insignia NSDSC10A Digital Camera
HOW DO I SET TIME AND DATE?
The Date & Time have been reset message appears after the Language screen the first time you turn on the camera. It may also appear if the batteries are removed for an extended time.
  1. SET DATE & TIME is highlighted. Press the OK button.
    (Select CANCEL to set the date and time at a later time.)
  2. Go to Step 4 below, Setting the date & time, anytime..
  1. In any mode, press the Menu button.
  2. Press autourg00205001id1456505.jpg to highlight Setup Menu autourg00205001id1561971.jpg, then press the OK button.
  3. Highlight Date & Time, then press the OK button.
  4. Press autourg00205001id1474816.jpg to adjust the date and time. Press autourg00205001id1474821.jpg to advance to the next setting.
  5. When finished, press the OK button.
  6. Press the Menu button to exit.
Aug 27, 2010 | Kodak Cameras
Settings on the date and the year
To Set the date:
1. Press the Up/Down button to enter the Set Date option.
2. Press the OK/MENU button.
29
3. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
4. Press the Up/Down button to set the Date and Time digits.
5. Select the first option of the Date format and press the Up/Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
Mar 28, 2010 | Vivitar Vivicam 8225 Digital Camera
Change date and time
This can only be done if you have the Fax option fitted. Assuming you have then :
Press the SPECIAL FUNCTION key
Scroll down to KEY OP PRG and press OK
Enter the Key Op code - default is 00000
Scroll to FAX and press OK
scroll to INITIAL SETTING and press OK
Scroll to DATE & TIME SET and press OK
Enter the Year, Date and Month if required and Press OK
Enter the time (in 12 hour format) , press OK then select AM or PM and press OK
press the CA button to exit.
Mar 15, 2010 | Sharp AR-M208N Copier
How to re-set date in the camera?
turn on your camera and go to menu. top of the screen you will see 3 camera tabs. choose the 3rd screen with the wrench on the camera. this will take you to what you need to change the date. scroll down the screen till you see 'Date & Time', then open it up by pressing the 'ok' button. You should be seeing a screen that asks you to set format. continue to the month, date and year, then time after you have entered your settings, press ok. after your done, press menu button to return to the viewing screen for picure taking. your camera may go to a blank (black) screen while no action is taken. If this happens, just press your menu key and return to the 3rd tab and proceed with the instructions.
Aug 23, 2009 | Kodak EasyShare M863 Digital Camera
Time & Date
1. To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
2. Press the "SET" button 2 times until you see:
USER SETTINGS - 1. DATE & TIME.
3. To open the DATE & TIME Menu. Press SET.
Use the buttons on the numeric keypad to enter the current month, day, year and current time. Just enter the new numbers over the old numbers.
To set the year, enter 08, 09, etc.
Use the 24-hours format to enter the time (e.g. 1:00 p.m. would be entered as 13:00)
You can also use the cursor buttons to move the cursor without changing a number entry.
To restore previous entry, press CLEAR.
Press SET to "lock in" the Date and Time.
Jul 10, 2009 | Canon LaserCLASS Fax 710 Printer
Cameras Logo
52 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
