Question about Intel D845GVSR Motherboard
Hanging problem system(processor intel pentium4 2.4,845gvsr,128&512 ram 266mhz)frequently hangs stops responding and mouse pointer also stops functioning,alt+ctrl+del does not works
  • jagadeesh23s Sep 22, 2008
    my system is hanging alwase .......for every one minute..
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Posted on Sep 08, 2008
Wardware boting problem
Posted on May 15, 2011
D845GBV no display in skrin.tone continuously few seconds nonstop.
RAM: already change and no problem
AGP CARD: already change and no problem
  • eone_solutio Sep 08, 2008
    D845GBV no display in skrin.bib tone continuously few seconds nonstop.
No display and hear bib code.
Check the RAM 1st, clean the contact point & insert in slot reboot the system. if problem not solved use second slot most of the time hanging problems is solved . further you can check the programs that you installed after which hanging problem occurs, uninstall that prog or restore to sysstem to back dates.
Posted on Sep 03, 2008
My sony vaio laptop is always hang 5 to 7 mins. but mouse pointer is still moving. all application im working are stuck a few minutes. what are the possible solution for this problem. i do reformat but...
Please backup the data by logging in to Safe Mode, please restart and start pressing F8 key to select Safe Mode then re-install the Windows 7 Operating System using the Recovery Disc or recovery Partition of the Hard Drive. The Recovery Partition can be accessed by restarting the computer and try pressing F10 Key. The Windows XP Operating System is displaying an error because it does not have SATA Driver to detect the Hard Drive. As Windows 7 has it, you can re-install it from recovery partition.
Mar 24, 2011 | Sony VAIO (PCWA-A200)
My Mother is Intel D945GNT with Intel D Processor. Ipurchased it in 2006. From that time till 2007 it works properly. After that there is hang problem comming, and during hang also the display became hazi...
The onboard video chip is dying. Since it's a part of the chipset, it might be also dying. If you're lucky all you need to do is to add a separate video card, disable the onboard video and your problem will go away.
Jul 31, 2010 | Intel D945GNT Motherboard
Intel D865 GBF system hangs oftenly
Hello,This always happen when the processor is bad or faulty. when the system is working, check if the processor fan is working too, if the processor is working that means the CPU is faulty.leave the system open and power it on to see if it will hang.
Aug 11, 2009 | Intel D865GBF Motherboard
System hangs up frequently
Might be a loose RAM (memory stick). Try removing it and then connect it again properly and see if it solves the Problem.
Jul 12, 2009 | Intel Pentium Dual-core Processor E5200...
I have the same problem
check to see if the CPU is connected to ur motherboard securly and check RAM aswell.
Jun 06, 2009 | Intel D845GVSR Motherboard
Computer hangs during xp installation
make sure you have met the minimum hardware requierments when installing your XP...which is
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Apr 11, 2009 | Microsoft Windows XP Professional for PC
My computer hangs frequently after successful booting. Every time i have to re boot to proceed. Please help me to solve this problem.
hanging of system may several causes, first of all check for viruses un the system, check proper drivers installed in the devie manger.
Mar 22, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
System in hanging
try to replace your RAM
Jan 13, 2009 | Intel Motherboard
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
Keyboard and mouse problem
1. You can disconnect the Hard disk then test the system if keybaord and mouse working, then there i s problem with your operating system or RAM.
2. Processor fan will rotate even after system hang up.
3. Check the RAM for cause
4. Operating may need to reinstall
May 25, 2008 | Intel D101GGC Motherboard
Intel D845GVSR Motherboard Logo
154 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
