Question about Maytag MBB1956GES Bottom Freezer Refrigerator
Refrigerator not cooling
The refrigerator is making a clicking noise and it is not cooling. The freezer compartment is also now at room temperature.
Please help.
G. Lee
    President:
  • 1,462 Answers
The clicking noise is probably the compressor srart relay opoerating but the compressor not starting. compressor faulty and an expensive repair
Posted on Sep 03, 2008
Not cooling or freezing
Hi Mick, this is AP.
I understand you are experiencing a no cool situation in your Frigidaire refrigerator. On your model, FRS26R4A, specifically the first thing to check it to make sure the refrigerator and freezer controls are not set to "0", turning the Freezer and Fresh Food Controls to "0" turns off the compressor and prevents your refrigerator from cooling, but does not disconnect the power to the light bulb and other electrical components. If you hear the noise coming from the freezer compartment it could be something blocking the evaporator fan which would cause warm temps in the fresh food and freezer section. If the noise is coming from behind the appliance it could be something in the condenser fan or the compressor may be locked up. I would definitely recommend contacting an authorized technician to repair your appliance if you find the temperature controls are not the cause of your high temperatures in the refrigerator. I hope this information helps.
Thanks,
Apr 01, 2014 | Frigidaire FRS26R4A Side by Side...
I have a Magic Chef MCBR1000W. The recent east coast earthquake shook the freezer door open while I was away on vacation. When I returned three days later, the freezer compartment (open) and refrigerator...
Quite often when the door gets open for a extended period of time the vents in the ceiling of refrig.compantment where the cold air from the freezer enters the ref.section...by looking up in the rear of the ref.ceiling you should be able to see these vents and see if they are frozen..if they are frozen a hair blow dryer will thaw them
Where here in the east coast are ya im 20 miles north of the epicenter in dumfries va
Aug 28, 2011 | Magic Chef CTN1521 Top Freezer...
My French door Maytag shows that my freezer temp is -2 and my fridge compartment is 40, but both are not cooling. it is now room temperature inside.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerator is not cold, freezer is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 26, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
My frig is not cold enough
Maybe the room you store it in is to hot as the fridge will only cool a certain amount of degree's below the ambient temperature, if it has a freezer compartment make sure it is regulary deforsted as the fridge temperature is linked to the freezer temperature.
Regards
chris
Jan 15, 2010 | KitchenAid Refrigerators
Frigidaire Side-by-side not cooling or freezing
Dear customer,
We suggest u to do the follwoing checks,
  1. Hissing and popping is normal on frost free refrigerators, it is the defrost heater
  2. Check that the refrigerator is level
  3. Check the drain pan
  4. Check the condensor fan
  5. Check the evaporator fan
  6. Inspect the compressor mounts
As for th freezer's problem checkout the,
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the freezer or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak.
Thank you. Plz rate the solution..
Apr 08, 2009 | Frigidaire FRS26R4A Side by Side...
Kenmore refrigerator 253.57192600 making clicking noise
It could be as simple as a bit of expansion and contraction of the wall panels or the damper which allows cooling to flow from the freezer to the fridge side.
Mar 08, 2009 | Refrigerators
Maytag MBB1956GES Bottom Freezer Refrigerator Logo
248 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
