Question about NEC MobilePro 900 Handheld
Open the modem door
Why can't I open the modem door fully?
    Master:
  • 903 Answers
The modem door does not open beyond a 45 degree angle to the base unit. Damage to the modem door will occur if forced open beyond a 45 degree angle.Open the manual for additional details.
Posted on Sep 14, 2005
SOURCE:
This is a basic question. We have old fashioned tilt up garage doors. They are wood and use springs on each side to open the doors and keep them open. I want to adjust the springs because: 1 one door will...
you move them up or down on the chain link on the bottom or on the holes on the garage door frame where they attach at the top. proper adjustment has the door open about half way with free travel on the opener. you also can change the size/length of the spring to adjust tension one way or the other. generally the best adjustment is from the bottom. an obviously, it is easiest to move the springs when the door is fully open. block it fully open with a long 2x4 or something as you do this, otherwise the door will fall good luck
Mar 27, 2015 | Building Materials
Sliding door
It may have a switch which engages when the door is fully open, if the switch is bad then the door would continue to try to open (too far)
Nov 01, 2013 | 2007 Honda Odyssey
How do i reprogram the power sliding door on a 2005 buick terraza
From the owner's manual:
If your vehicle has
the dual power sliding doors, both doors will have
to be reset. To reset a door, do the following:
1. Check to be sure the power sliding door is
unlocked and securely closed.
2. Turn the ignition to LOCK.
3. If the power sliding door overhead console
switch is in the override (deactivation)
position, return to the activation position.
4. Open the sliding door using the remote
keyless entry transmitter, overhead console
switch, or passenger switch. Allow the door to
travel fully open.
If the door does not travel to the fully open
position, press the overhead console switch to the
override (deactivation) position and slide the
door fully open and closed. Check for foreign
objects in the tracks. Repeat the procedure starting
with Step 1. If the door resists travel to the fully
open position, see your retailer for service.
Dec 27, 2012 | 2006 Buick Terraza
I get a Red E1 and a green F5
The F5-E1 error code means that one of the switches on the door latch hasn't fully set itself to the door open(non clean) mode. One thing to try is to open the oven door and push the light switch in by hand while pushing the clean button on the control and see if the latch will open just a little more thusly the switch will open a bit more into the normal mode.
If by pushing the clean button...waiting 5 minutes (whith the door open)then push cancel and see if the latch fully opens..the door latch switch would need to be replaced.
GENE
Sep 05, 2011 | Whirlpool Ovens
Every time I push the opener button the chain goes about an inch and stops abruptly. The door is not able to be opened or closed as a result. Is this an adjustment problem?
Disconnect the opener from the door.
Lift the door and ensure that it moves freely from fully open to fully closed.
Try to operate the opener. Does it go all the way from open to cloosed?
If the door operates smoothly and the opener works without the door connected, check the up/down force adjustment on the body of the opener.
Dec 01, 2010 | liftmaster Chamberlain Garage Door Opener...
Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
May 19, 2010 | Dishwashers
Beocenter 9300 - doors don't full open
no,motor drive on timeout.usual cause friction between door and guide rails,only way to check is to remove doors and clean/lube door guide pins.this is not an easy job,very fiddly as involves detaching doors from cord drives.you may also have low motor cct supply voltage.
Mar 28, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Door open signal flashing -
First check to see that the door switch is closed fully when the door is closed. Tape it fully shut to make sure
Jul 17, 2008 | Samsung RS2630SH Side by Side Refrigerator
MY PC
Sandi see care fully on your CD-DRIVER shutter, there might be a narrow hole, just like that only a niddle can be inserted.
Actually this hole is made for opening the door in emergency or if got stuck.
what you have to do, is just insert a long niddle or hard-wire or hard-stic, and try to push the lock inside gently. As well as you push you feel the openning of shutter. Just push slightly more and drag out the tray by hand....... and njoy..
good luck.
and don't forget to rate this solution.
Thanks
Iqbal
Mar 24, 2008 | Packard Bell (090317) Modem
NEC MobilePro 900 Handheld Logo
364 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
