Question about Panasonic PV-DF2000 20 in. TV/VCR/DVD Combo
Panasonic PV DF-2000
My TV plays DVD's in Black/White with sound, Broadcast (channels) with color but without sound and the main menu don't change selection ( I can't set the hour, color, DVD fuctions, etc)
4 Suggested Answers
  • 21 Answers
SOURCE: can't find comcast remote codes for panasonic
Most universal remotes will not work with TV/DVD/VCR combos . Sorry!
Posted on Mar 26, 2009
  • 4 Answers
SOURCE: program menu on panasonic pv-m2037
I found a solution to my problem...my son finally broke that TV and my husband found a better flat screen 32" and it works well with the Shaw remote. It sounds really good and great picture. And to top it off he only bought it for 50$ so it was a steal in Kjiji.ca. Maybe kijiji will solve your problem too.
Cheers!!
Posted on May 23, 2009
  • 476 Answers
SOURCE: Panasonic pv-c1350w channel/clock auto set
You are probably talking about the main menu that appears when the TV is taken off the AC power outlet, to get rid of this page just turn the tv off and on again and it should give you access to what ever channel was tuned before, if your game console has an RF out, your TV should be set to channel 3 ir 4, if the console has composite outs the change the channel until the TV goes to Aux in or Video in. Retrevo.com has an instruction manual available which you can download free, just in case you need more informantion, if the channel keys do not work, then you may have to get a universal remote ,they are fairly inexpensive and will come in very handy at least for the basic functions or just have theTV worked on.
Posted on May 12, 2010
How do I access the main menu on a panasonic triple play TV without the remote
asking the same question, and before anyone answers, there is no action button on the tv
Oct 26, 2012 | Panasonic PV-DM2792 Triple Play 27 in....
How would you go about resetting channels without the remote control
If there's no option for it within the TV's menu, or if you can't get to the menu with the buttons on the set itself, then you should think about getting a decent universal remote with DVD functions. If it's a TV from a mostly unknown company, you're kinda out of luck. They may be cheaper, but you're up ****'s creek without a paddle when they break down.
Jun 04, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Panasonic DVD-RV31 DVD Player plays black & white only (no color)
Hi,make sure your tv channel says av2 and not av2s as this will play in b/w,hope this helps
Jul 10, 2009 | Panasonic DVD-RV31 DVD Player
A/V in black and white
good day,
what video device do you plug in to your TV screen, DVD player/VCR or game console?
If you still have the owners manual of your TV screen, look for instruction regarding Color system or video system. this menu will allow you to change color sytem from PAL to NTSC or AUTO system.
most likely the reason why you have a black and white color from vidoe input is because of system color compatibilty from your input device to your screen.
Or if your using a dvd player, you can also try accessing the "setup" button and look for video setting. from the video setting there will be selection to choose from: PAL , NTSC, AUTO . always select "auto"
so that the color system of your DVD player can change from PAL to NTSC deffending on your TV screen system setup.
cheers,
mark
Feb 01, 2009 | Sanyo Over-the-Ear Sleek Boom Microphone...
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
DVD player will only play in black and white
are you using a/v inputs or composite inputs .
Mar 27, 2008 | Disney Princess TV/DVD Combo
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
DVD's will no longer play in color
We had the identical problem, which was solved by changing the input channel on our Panasonic plasma screen. This was not obvious and we needed help from the person who installed the system. The input channel had changed automatically!
Feb 07, 2007 | Sony DAV-S300 System
Panasonic PV-DF2000 20 in. TV/VCR/DVD Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
