I replaced the serpentine belt and now have a terrible screeching with the a/c is turned on.
A couple of things come to mind: if it wasn't screeching before replacing the belt, you may not have routed the belt properly - especially around the belt tensioner pulley; or the bearing on that pulley may need lubrication or replacement; or the A/C compressor bearing may have failed causing excessive resistance on the new belt resulting in screeching. Also, if the belt was not routed properly, the screeching may be coming from another belt-driven (power steering pump, water pump, etc.) but it doesn't sow up until you engage the A/C with its additional drag.
no not before but after Thanks for the response
