Question about Canon CanoScan 5000F Flatbed Scanner
Scanned image only prints in black and white
I printed a text document (using fast black & white text) before this problem came up. Now, the scanner previews in color but what I print is always black & white. In preferences, I unclicked greyscale and clicked on color, but to no avail. I downloaded a twain driver from 2007 (I think it got installed) but doesn't help. Color from a web site prints fine. ?? Hope someone can help.. Thanks
It's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
now:
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
jepe
Posted on Oct 05, 2008
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
I have a iriscanner anywhere 2. When I scann a white piece of paper on my scanner the backround does not come out white. Then when I print it the printer prints the backround and uses a lot of ink. How do...
Almost every scanner can be set for color, greyscale, and black and white. For text only scanning, use black and white and ink will only be used for the text.
Sep 06, 2011 | Cameras
Want to print black and white. How?
Setting the font type color in a Microsoft Office Word document to black will ensure that the document prints the text in black. However, if there are images, graphics or photographs within the document, they will more than likely print in color or hued colors similar to black. To ensure that the entire document prints solely in black ink, you must set the color settings on your individual printer to black-and-white
Instructions:
1.Click "File" and then "Print." To open the print dialogue box using keyboard commands, press "CTRL" and "P" simultaneously.
2.Select the printer you are using at the top of the dialogue box under "Printer" and "Name."
3.Click the "Properties" button next to the selected printer. The dialogue box that appears is different for all users, as it depends on the type of printer being used.
4.Click on a tab, button or selection box indicating "Color." Most options include high-quality color, grayscale and black cartridge only. Choosing grayscale will print the document using various shades of gray and other tones such as blue or green that match the actual hues in the document visible on the screen. A photo or picture that may look black or gray could actually have blue undertones. To print purely in black and white with no undertones, you must select either "black cartridge" or "black and white only."
5.Select "OK" to return to the Microsoft Word printer dialogue box. Press the "Print" button to print the black-and-white document.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Computers & Internet
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    I'm having trouble scanning B&W documents with my Epson V300. The edges of the letters in the text are jagged and hard to read and there is what appears to be a crease or fold in the document when the...
    You have two options for scanning text. You may explore both of them and see which is better for you. Either way, you will have to make friends with manually changing the scanning settings, because simple presets often are not suited for every case.
    First is to use Grayscale mode, and a minimum resolution of 200dpi. This should give you satisfactory text quality. If you want to print the text afterwards, 300dpi would be even better. You may want to increase contrast, to get the letters more defined and eliminate most of the background toning.
    Second is to use Black and White (monochrome) mode, but in this case you need to set the resolution higher, preferrably to 600dpi. Also in this case you will have to play with the Black/White threshold in order to eliminate background "dirt" appearing as black artefacts.
    If you scan the documents in order to process them with OCR software, usually the OCR application will give you suggestions on how to set the scanning parameters to obtain good results.
    Jan 24, 2010 | Epson Perfection V300 Film Flatbed Scanner
    When scanning color document, blue tone is present as background shade
    Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
    Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
    Scanned Items or Copies all print in Solid Black
    I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
    Color Image Prints in Black and White
    Good luck.
    Sep 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
    Blurry Scanning/Copying
    Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
    Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
    Canon CanoScan 5000F Flatbed Scanner Logo
    170 people viewed this question
    old marine
    old marine
