Question about Rinnai Heating & Cooling
Have an old Rinnai Gas Heater (approximately 30 years old) still working well, but we had to turn off the gas, and now cannot turn it on again. We have two buttons, one below the other, one is red and say On, the other is black. We also have an ignition button at the side. However, we were under the impression that we had to push the red button to get the pilot alight, then hold it there for a few seconds for it to fire up BUT the pilot light does not stay on - just fades away. Can't find instructions. Can you help?
    An expert who has answered 500 questions.
  • 540 Answers
You are half-way right, to light the pilot, light it and push down the red button and hold it for at ----least2-minutes-- till the flame heats up the pin (thermocouple- which fire-thermocouple metal makes electricity which sends it to the gas valve and says ,OK GAS VALVE,I'VE GOT A PILOT FLAME SO OPEN UP THE MAIN GAS VALVE! See where I'm going with this?
Posted on Sep 03, 2008
E:01 fault on a rinnai energysaver 403FT
Rinnai 403FT sounds like a fairly old heater (probably about 15 years old???).
There is no E:01 in the instruction manual but a E:07 which is overheating. Could it be this number instead? If so it could be caused by too much dust inside (or the fan not working anymore, if that's the case... sorry but good luck to find the part...)
With gas heaters, the other basic question you should ask yourself is "when was the last time I serviced my heater??". It is recommended to get them serviced every 1 or 2 years.
It consist in having a licensed gas fitter to open it and clean/test everything inside the heater (yes, like your car).
9 out of 10 problems with a gas heater are solved with a simple service, I would suggest you get a gas fitter to check it out!
Apr 20, 2013 | Heating & Cooling
Converting rinnai 516tr from natural gas to lp
Try national energy they sell convestion kits It would need a gas fitter to do the work , you may need to a quote on this , they would be able to tell you if it is worth it ,its hard to tell with out looking at the heater .
Feb 24, 2012 | Rinnai Heating & Cooling
Have a rinnae royal gas lok heater. Cant start it after gas was shut off. How do you get the ignition to work and start the pilot light again
When the gas was turned OFF, air got in the line(s) and created an air pocket. This air will need to purged from the system, before the heater will light. It only the shutoff valve on the gas line to the heater was turned OFF, it will be easier to purge. If your Rinnai heater has manual ignition rather than electronic ignition. Holding the control down in the Pilot position, will eventually purge the air. If you have electronic ignition, continually trying to light the unit will do the same thing, but take longer to accomplish. Consulting your Rinnai will also help you with this situation.
Hope this helps you and thanks for choosing FixYa.
Jul 28, 2011 | Rinnai Heating & Cooling
Have a Rinnai Energy Saver 551 F gas heater. When the heater is switched on it then turns itself off after approximately 5 minutes
Stuart, I beleive the model number you have is Rinnai, Model 151 Portable Gas Heater (Meaning it's flue-less). If that is the case, the Oxygen Depletion Sensor (ODS), which is part of the Pilot, may be clogged with dust, lint, pet hair, etc. In which case, cleaning it, with canned compressed air with a straw nozzle (like you clean your computer with) can solve the problem. Also, cleaning the entire interior of the heater is a prudent thing to do, at least once a year. A vacuum cleaner that has a hose and brush attachment works well for this. To assist you, I have included a link to "How to clean your Pilot and Burner Assembly" Demonstration, as well as a link to the Owner's Manual for you Model Rinnai Portable Gas Heater.
Cleaning Demonstration:
Owner's Manual:
I hope this has helped you troubleshoot and solve the problem. Please let me know. Cheers!
Jun 21, 2011 | Rinnai Heating & Cooling
Following removal of filters from Rinnai gas heater (2 years old), I vacuumed both filter and back of gas heater but it still smells ilke gas when filters putr back on and heater tunred on.
Although you cleaned the filter and vacuumed the outside of the heater, there is probably a dust and dirt build up inside the heater, that also needs to be cleaned out. A dust build up can clog the burners so that they do not burn cleanly and thereby produce a gas odor, Be sure you turn the heater OFF and let it cool completely, before removing the heater's cabinet. A Shop Vac with a brush attachment on the hose and a can of compressed air with a straw nozzle (like you clean your computer with) works well in performing the cleaning process. Be sure to not only clean the burners, also clean the pilot and the pilot assembly.
If after completing the above, you still get a gas odor (if it doesn't smell like rotten eggs, it's not gas), it would be wise to perform a leak check on all the fittings. With that said, it's normal to get a whiff of gas when the burner lights and turns OFF, But, it should dissipate quickly.
Hope this helps you further troubleshoot and solve the problem. Please let me know. Thanks.
May 07, 2011 | Rinnai Heating & Cooling
I have a rinnai gas heater and it has 2 broken burners and im tryiny to find new burners
Rinnai spares are available from the company through service agents depending on where you are. Let me know the model, approximate year you bought it and where you live and I might be able to find out who is closest to you or at least a number to ring.
You could try on the web
Jul 08, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai RCE-606A vent free space heater, the Lock
Hold the lock button down for approximately one second to switch between locked and unlock. If it is locked when you turn it on you will need to do this first
Mar 13, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
I have a Rinnai 308FTR heater and the first time I
Means failed ignition/no gas.
Check gas supply.
Mar 05, 2009 | Heating & Cooling
Rinnai gas water heater wont heat the water hot enough even though we have turned the thermostat up to 185.
your temp control is bad and you will have to have a tech to service the unit, contact rinnai and they will give you info on a quilified repair person,, not just any one should be allowed to work on it,, depending on the age it may still be under warranty,, they come with 5 year parts 1 year labor 12 years on heat exchanger this is on all rinnai units
Feb 18, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
228 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
