Question about Toshiba Computers & Internet
Toshiba laptop L10-205 have no display
HI,
I am faceing a problem on my toshiba laptop. two day back while i was opening an email the laptop when to off mode suddenly and when i tried to restart the HDD is reaing , but no display. i tried to connect an external monitor and pressed the FN key +F5 while the strt up time but no display.
I would appreciate if any1 could healp to solve this issue.
thanks
hari
  • harikpillai Sep 04, 2008
    Finally I fix thru trial & error method. Memory Issues!!! I replaced it.
    Problem Solver:
  • 18 Answers
Hi! you should try removing the hard drive and restarting your laptop with your windows cd in it. if this works then switch off and slot the hard drive back in & reboot. if the display still doesnt work, then the strap / cable that connects the laptop screen to the laptop is damaged. then only should u take it to the dealer for repairs.
Posted on Sep 03, 2008
Hi there I have got a toshiba satellite c50d-b-120 laptop and the other day I turned it off then in the morning I woke up and tried to turn it on but won't start need help asap
Verify the power adapter is working with multimeter. Should display 19.5v
Drain capacitors - Remove power plug and battery from laptop. Hold power button down for 30 seconds. Put battery back in and plug in. Try to turn it on.
If it turns on but you are getting no display, plug in an external monitor to see if it's a display issue
Jan 25, 2016 | Toshiba Computers & Internet
I have toshiba c660. its built webcam was working perfectly. but few days back when i used it a blue light turned on but after closing the web cam blue light was still on but light was dim. when i opened...
Restart the computer and see if the blue light comes back on by itself. If you are still having problems visit the Toshiba support site for your country (or region). Download the webcam application compatible with your version of Windows (32 bits, 64 bits) and reinstall the application. Test it using the Start>Toshiba>Utilities>Webcam Application, or the Face recognition software. You close the running application by clicking the x at the top right corner of the application window
Oct 27, 2013 | Toshiba satellite c660
I'm trying to figure out a toshiba satellite l455d-s5976 laptop. It shuts off automatically. If you leave it off for days, then it will run longer (30-60minutes) before it shuts off. Once it's off, you can...
It's difficult to determine the exact cause of the problem but from your description it would appear that the laptop CPU is overheating. This would cause it to shut down as a safety mechanism to prevent your CPU or other components from permanent damage.
The first thing you need to do is open the laptop or have it opened by somebody in the know.
There are inlet & outlet vents whereby air is sucked in over the CPU which helps to keep it cool. These vents have filters which become blocked by dust & other debris in the air.
Cleaning the dust from these filters often sorts out overheating problems.
If this is not helpful in your case, it would be advisable to have a technician do further tests to determine the problem
Best wishes,
Graeme
Mar 11, 2011 | Toshiba Satellite L455D-S5976 Notebook
Toshiba satellite A55 -s106 back light dost work needs replaced
Laptop computers: 1–800–457–7777 Toshiba's Technical Support is open 24 hours a day, 7 days a week
www.pcsupport.toshiba.com.
May 12, 2010 | Toshiba Satellite A55-S106 (PSA50U0NE02E)...
HI , I have a Toshiba satellite L350 laptop and i
Please check the display driver is installed or not or open device manager right click on the display adapter and select Update driver and then check the issue..
Feb 02, 2010 | Toshiba Satellite Pro L350-S1001X Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Garbage display
Hi, i have the same model TOSHIBA protege s100, i cant installing a fresh copy of Windows XP Pro onto a Toshiba Portege S100 laptop.
the error is "Setup did not find any hard disk drives"
Please reply
Thanks
new_concept2006@yahoo.com
Aug 01, 2008 | Toshiba Portege S100-S1133 Notebook
Display problem for toshiba satellite dynabook
go to toshiba website sellect the area that is closes to you, then go the contact details and email your problem to them
http://www.toshiba.co.jp/worldwide/index.html
good luck
Feb 20, 2008 | Computers & Internet
Toshiba a100-psaakl
Please let us know what your operating system is
Jan 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
196 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
