Question about Nintendo Wii Fit for Wii
WII FIT CANNOT READ DISC
Bought  the Wii Fit after almost a month of scavenging online and in shops. Played and tested it, third day it conked out saying cannot read disc. I thought some lens problem, tested my other Wii games with no problem at all.
Anyone got idea to sort this out? I don't want any solution of returning it to the shops or technical support which is the last resort. Thanks.
  • 5 more comments
  • beccabo22 Dec 27, 2008
    last night for christmas i got WII fit i played for about twenty minuets last night now when ever i put it in it reads the disk for a moment or two but once it get on to the whole adjust you ******** your WII and safety rules the screen goes white and then it will tell me the disk cannot be read i read the whole users manual wiped my disk with my cloth for wiping my glasses and it still wont work IM SO SAD WHAT CAN I DO HAVE YOU FOUND A SOLUTION????
  • dungeonx Jan 20, 2009
    Same here I insert the disk and click start, i hear a couple beeps and then i get the game disk error refer to my manual screen. everythig else seems to work fine...? Right now I am pissed
  • supaxnerd09 Jan 21, 2009
    Mine started saying cannot read disk after two day's with having the game and wii then all of my games started doing it and so i contacted nintendo and sent my wii to them and i got it back today, and i still can't play wii fit.
  • redrady1 Apr 05, 2009
    we have had Wii fit since last summer. All of our data is saved. We play it at least once a day! Today, no matter what we do, it says it cannot read disk. We just systme upgraded last week. We've cleaned the disk. It has NO WARPING. What could be wrong?
  • Anonymous Apr 16, 2009
    I can do a body test but when I go to training, the disc won't read.
    I can do a body test but when I go to training the disc won't read
  • VentureForth May 11, 2010
    Have you run the latest system upgrade? From the Wii Menu screen, click on the Wii Settings. On the top right corner of the screen, it should say something like 3.3U. If it shows 3.2U or lower, then the operating system is in need of an upgrade. If you do not have access to the internet through your Wii, this can be a challenge. I don't know if this will solve the problem or not, thus only offered as a clarification.
SOURCE: Can't Get Started my Wii Fit because CD Can't Be Read
Be sure the disk is clean, and if that does not work, exchange it at the store it was purchased at for a new one. There have been many Wii games shipping with the wrong region CD.
Posted on Jan 14, 2009
SOURCE: "Step Off Me and Press A" message while not on wii board
When you get this message, lift the board off the ground, press A, and wait until you get to the confirmation screen before placing the board back on the ground. You may have to try a few times to get the timing right. I have no idea why it thinks someone is on the board, but this workaround has solved the problem for us. Good luck.
Posted on Feb 25, 2009
Meganerd X
  • 117 Answers
SOURCE: wii fit board blinking
Did you try pushing and holding sync on the wii and the board? that should work
Posted on Apr 10, 2009
  • 80 Answers
SOURCE: after loading the wii fit disc and selecting wii
Make sure that the CD is clean with no scratches.
Posted on May 07, 2009
cene765
  • 787 Answers
SOURCE: My Wii wont read ANY WII fit discs but will read
Check the Wii Fit discs region.If your Wii is USA(NTSC) can't read Europe(PAL) discs or back.
Posted on Nov 03, 2009
My wii fit plus disc reads cant be read when inserted in to the wii help please can it be fixed
Hi lyned1,
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
Thanks for using Fixya.
Jan 28, 2011 | Video Game Consoles & Games
It doesn't recognize the wii fit plus disc it tells me to insert disc
Are you inserting the disc properly? And when is the last time you ran a laser lens cleaner through your Wii system. Dust and contaminants can cause disc read errors.
Oct 28, 2010 | Nintendo Wii Fit for Wii
Disc doesn't work when I change from body test to training on Wii
Wii Fit? The problem can be that your Wii is modded (IF ITS MODDED), or that the disc contains scratches.
Nov 21, 2009 | Nintendo Wii Console
Unable to read disc
If (1) this error only occurs with the Wii Fit game and (2) you have no scratches or marks on the game disc and (3) you have cleaned your Wii with a lens cleaner product recently; then, most likely the Wii Fit game disc is bad.It's not your Wii.
here's the problem: the wii fit game is 4.7gb. Most wii games are 4.4gb. Burning a Wii game at 2x speed is fine if its 4.4gb.
For Wii games that are 4.7gb (full size of a DVD disc) the games must be burned at 1x speed or errors will occur.
It is likely that Nintendo burned these at 2x speed and therefore your wii is getting an error due to them incorrectly burning the disc.
Aug 18, 2009 | Nintendo Wii Console
I get a can't read disc message with my wii fit
even small scratches can cause disk read errors. Try cleaning it again with a little white spirit using a soft cotton cloth then dry it off with a soft cotton cloth. If it still does not read, a lot of 'game' shops repair scratched disks for about £3.00.
I hope this helps
Jan 17, 2009 | Nintendo Wii Console
I got wii fit the disk wont work !!!!!!
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 27, 2008 | Nintendo Wii Console
Wii frezees after inserting Wii Fit Disc!!
You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 06, 2008 | Nintendo Wii Console
Buzz & Not reading disk
check to see if something might have gotten inside the cdrom player.
Jul 01, 2008 | Nintendo Wii Console
Nintendo Wii Fit for Wii Logo
879 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
