Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Dispenser does not dispense
Hi Micbeth19...Thew dispenser does not dispense ICE or Water. Eventhough there is plenty of ice in the ICE bin. It does make ice but no water or ice thru dispenser. Please respond.
  • Anonymous Mar 20, 2014
    water and ice is not dispensing
  • 1,122 Answers
Posted on Sep 13, 2008
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:--- ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- -----------
You can get required parts from online sites like: --- or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
Door dispenser will not dispense the ice.
you and many others have this problem . ( tip remove bin and rinse out with warm water dry it well and the door area also then the majic ... spray the dispenser with ( pam ) without the butter . clean and slick . this should help . mm
Jul 02, 2010 | Whirlpool ED2FHEXN Side by Side...
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Sep 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
Ice dispenser wont dispense. Sounds like it egages
Remove the bin and you probably have ice caught in the auger .
Jun 30, 2009 | Refrigerators
Check this first,
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see “Ice
Maker & Storage Bin.”
 Press and hold LOCKOUT for 3 seconds to lock the
 Press and hold LOCKOUT a second time to unlock the dispenser.
Let me know if this helped, Sea Breeze
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
 Is the ice dispenser stalling while dispensing “crushed”
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
The Dispenser Lock (on some models)
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
255 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
