Question about Teac Audio Players & Recorders
CD player TEAC DC-D350 When inserting CD >>message 'disc' shows up. Suspect Laser diode faulty. Should the Laser be on only with CD inserted ? or anytime when player is 'ON'...?
  • kimfrances Sep 03, 2008
    Laser is not on with CD inserted either, also: the motor does not turn when inserting CD.
    (Tray drives ok in and out)
  • 56 Answers
It must probably be a laser faulty, however it could also be derived from something that you can solve by cleaning.. The laser should be on only with cd inserted.
Posted on Sep 03, 2008
XDVD710 Whenever I try playing DVDs the screen says bad disc the CD and tuner works fine but with the disc inserted I hear thedisc sspinning with occasional beeps then get the bad disc message and the disc...
The laser unit is most likely faulty and requires replacement. There are usually separate laser diodes for the CD & DVD reading, so the CD might work perfectly while the DVD won't.
Jan 18, 2014 | Televison & Video
CD player reads
Laser dirty or faulty. Try it with a different audio CD. Usually its easier to replace the whole thing than to take it apart and change the laser unit.
Jun 20, 2012 | Teac CD-P1250 CD Player
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
I have a philips hts6510 home theatre system and when i put a dvd in to play it says no disc
hi,
Normally a dvd player shows the message NO DISC when,
1. The disc inserted is bad.
2 The lase pickup unit inside the dvd lost its reading intensity, dirty lens or the spindle motor damaged .
In your case the second one happened. the intensity of the laser pickup unit has lost or the spindle motor faulty or there is some dust on its lens. just insert a cleaning cd in it for two or three times. then check again is the DVD is reading or not
if the problem remains then you have to check the motor and the laser pickup unit. the lase pickup unit have two laser emitter and receiver in its inside . one for reading and playing DVDs and the other for CD and MP3. also the spindle motor runs in different speed when u insert dvd and cd.
Open the cover of your dvd player and power it on insert an audio cd and watch is it reading or not also notice the speed of the spindling of the cd. if the audio cd reads and play. then the possible problem is the spindle motor
To conform it remove the audio cd and insert a dvd. watch the rotation of the dvd. if it feel very hard to rotate it then, the spindle motor is damaged. if so replace the spindle motor if it runs more the the speed of than audio cd then the laser pickup unit is faulty. Then u have to replace the laser pickup unit.
if you need any further assistance from me , feel free to contact me through fixya.
ok
Jan 16, 2011 | Philips HTS-6500/37 System
I have a thinkpad and running on windows 2000 pro. inop
Check with other discs. If you still receive such an error, you drive might be faulty
Mar 30, 2009 | Teac DW 28E CD-RW/DVD-ROM Burner
CD Player does not recognize CD
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Oct 05, 2008 | Teac DC-D2831 CD Shelf System
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Oct 17, 2007 | Blaupunkt RPD 552 CD Player
"no disc" message
sounds like you have a problem with the laser.laser has to focus a lot sharper to play dvd thus will play vcd but not dvd.Try cleaning first and if this doesnt work would suspect laser faulty,.
May 29, 2007 | Cyberhome CH-DVD 300 DVD Player
109 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
