Question about Bosch MUM4420UC Compact Series Stand Mixer
Dough hook & beaters slipping
Actually this mixer is labeled "MUM 44" I inherited it. Seemed to work o.k. however the dough hook and/or beaters are slipping agianst small resistance of what ever is in the bowl. It seems that the gears may either not engaging or maybe worn. Is there a place that I could get the machine repaired. I've found much pleasure in using attachments etc, it's a great appliance.
  • trb3 Sep 21, 2008
    Thank you for your response. Thanks for the link to Bosch repair center. I plant to contact them early next week/
    Brigadier General:
  • 6,966 Answers
Your unit is a BOSCH MUM 4405 ProfiMixx 44. This might be of use to your:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
  • 6,487 Answers
You can take it to Bosch service center for repair , check this link for the nearest service center in your location http://www.boschtools.com/Service/ServiceCenterLocator/Pages/default.aspx
Hope that helps........
    President:
  • 1,263 Answers
You can generally find a local repair shop that specializes in resturant/bakery equipment/small aplliance. they will have the parts you need as well.. good luck please rate this
I can't get the dough attachment off my Kitchenaid stand mixer. I have tried oil, filling up the bowl with soapy water and letting it stand overnight, pouring teapot after teapot of boiling water ove
Hi Georgette
You need to encourage movement between the beater and the silver shaft it locks on to. There is nothing that you can unscrew to make it easier. Get a can of CRC and try & get it around the silver shaft at the top of the beater plus you should be able to get a bit in that side slot where the beater engages with that driving pin. Rock (twist) the beater side to side and slowly the grip will loosen and you will be able to encourage it off. Once you have it off you will need to clean out the CRC and polish up that silver shaft. Next is the more difficult part, you need to polish up that hole in the beater. What you are trying to do is remove the build up of flour in the hole so that it is pretty much shiny in there again without being significantly bigger than it was originally. I use a rat tail (round) file to do this job, you are just removing the darker build up in there. When done a good wash and dry and it will be like new again. Keep the hole clean of flour and it may not happen again.
Nov 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Jan 05, 2010 | Hobart A200 Stand Mixer
Having a hard time removing the dough hook on the h-600.
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Dec 03, 2009 | Hobart H600 Stand Mixer
The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Jun 15, 2009 | KitchenAid KSM50PR Professional Series...
I need replacement beaters for a dough hook stand mixer
Information from manufacturer stating replacement parts have been exhausted.
Jan 30, 2009 | Food Mixers
Beater jams
You are going to DESTROY YOUR MIXER by kneading dough with the flat beater. Read the directions. They spell it out in big letters. Only use the dough hook for dough; only use speed 2.
If the mixer generated enough torque to knead dough with the flat beater (it doesn't), it would tear up and overwork the dough. As it is, you're lucky you didn't strip a gear.
Dec 23, 2007 | KitchenAid KP2671 Professional 6 Series...
Bosch MUM4420UC Compact Series Stand Mixer Logo
669 people viewed this question
Top Bosch Food Mixers Experts
Oscar Netto
Oscar Netto
Paul Bade
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
