Question about RCA Televison & Video
I have installed your analog/digital converter and it works very well,but I can not find a way to record a live tv program. can this be done?
  • RCA Master
  • 2,794 Answers
You will have to have the converter tuned into the channel. Use the AV output lines and plug them into a VCR or DVD recorder using a line in. Tune the VCR or DVD recorder into the line in channel and record that way.
Posted on Sep 03, 2008
Program my g.e remote control to a A.T.103 gematic digtal box
Tv Converter Box Deals
www.bestdeals.today/tv-converter-box
Digital Converter, Ematic Digital TV Converter Box with Recording, Playback, ...Digital to Analog TV Converter DTV Tuner Box w Remote, Program Guide, PLUS MORE! ... GE Television Antennas Omni TV Indoor Antenna 24731 ... HDMI/HDTV/DTV/RF/RCA/USB Digital Converter Box TV Tuner With Remote Control PVR.
Ematic DVR Recorder Television HDMI Media Player ...
www.altatac.com/p-15751-ematic-dvr-recorder-television-hdmi-media-p...
Ematic DVR Recorder Television HDMI Media Player Converter Box w/ USB ... TheEmatic AT103B Digital Converter box allows your TV without a digital ... Features an electronic program guide, parental controls, and a USB ... Full function remote controlincluded. .... My Account My Account Order Status Track Your Order.
At103b Ematic Converter Digital Atsc
antennadisht.com/at103b
11 ozmiscellaneouspackage contents converter box remote control 1 x user ... Review (mpn:at103b for sale) Digital Converter Atsc Ematic At103b Box . ... You can find your tracking number by ing on my and scrolling down to your purchase with us. ... Features an electronic program guide, parental controls, and a usb ...
Jan 24, 2016 | Televison & Video
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
Feb 11, 2012 | Zenith Televison & Video
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
My VCR not recording after the switch to digital tv signal
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website http://www.fcc.gov/cgb/consumerfacts/converterbox_vcr.html. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Scroll down to the Normal 0 false false false MicrosoftInternetExplorer4 section about “Set-up #2: Watch One Channel while Recording a Different Channel”.
Hope this helps
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
I have a new digital tv but can't get my vcr/dvd player recorder to work. Can I use the converter box on a digital tv? will it work to record and play.
The output connection from the VCR/DVD needs to be different for the new digital TV. Instead of using the RF output from the VCR, use the video and audio outputs and connect them to the video and audio inputs on the digital TV. When you want to watch the VCR, select "video in" on the TV. The digital converter box should be hooked to the input of the VCR so you can record programs off-air.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
How to record mutliple programs with a converter box
You will not be able to record like you used to: http://www.ezdigitaltv.com/VCRs_and_Converter_Boxes.html There are some boxes that have a timer, but not many.
Getting my VCR to record from the TV with a converter box hookup
Hook up antenna to converter box then from that out to the vcr's input (red,white, yellow connections are better than coaxial).
Jan 20, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
