Question about SanDisk Sansa E280 MP3 Player
Sansa e280 won't turn on
I have my girlfriends sansa e280, and it won't turn on unless it's plugged in to the computer. as soon as you disconnect the usb cable it shuts off.
any ideas?
Thanks!!
    Genius:
  • 1,239 Answers
Hi sir..
please install the firmware. i will solve it. follow thw link it will be useful www.woot.com/files/sansae200manual.pdf . rate it sir..
Posted on Sep 03, 2008
I re-formatted my Sansa e280 and now my computer does not recognize it. I am wanting to transfer music files only, using Windows Media Player.
Try to reset the device and if there is any driver for it, install them before connecting it to the computer.
Feb 28, 2011 | SanDisk Sansa E280 MP3 Player
My Sansa e280 won't turn on
Hold down the menu bottom for about 20-30 secs. Should power back on.
Mar 17, 2009 | SanDisk Sansa E280 MP3 Player
Mp3 turns off/on wont charge
one of my friends had the same problem
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
I hope my post was helpful let me know!!!!
Mar 10, 2009 | SanDisk Sansa E280 MP3 Player
Well my Sansa e280 wont come on. But when i plug it up to the....
Change the USB mode from MTP to MSC and see if that helps.
Also, make sure the hold/lock is not engaged.
Jan 06, 2009 | SanDisk Sansa E280 MP3 Player
Sansa e280 fatal failure - black screen, unrecognized by comp, won't restart..
1. turn sansa clip on
2. slide to "hold"
3. press and hold center button do NOT let go...
4. plug in the connector cable
5. wait until computer recognises Sansa device
6. let go of center button
7. drag n drop files and you are all set
if that doesnt work you will need to go to the sandisk website to update the firmware on your device..
let me know if you anymore questions..
Please rate accordingly
Thank you
Computerrep
Oct 31, 2008 | SanDisk Sansa E280 MP3 Player
Cant get songs onto my Sansa e280 player =[
"Refresh database" is a normal message that you will get everytime you unplug the Sansa from the computer - don't worry about that aspect.
If the songs that you have transferred have DRM encryption on them, they may not play right (or at all) on the Sansa.
If you have Windows Media Player 11, I would get the firmware update from the Sansa website AND format the Sansa inside Windows Media Player:
for the firmware,
for the format, http://www.sandisk.com/Retail/DriverDownloads.aspx
Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything and get your player functioning normally.
-Tha Mp3 Doctor
Mar 18, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280 malfunction
i have solved my problem !!
if it says connected and when you plug it and out and it is still not working you just plug then unplug (might take some time)
Nov 18, 2007 | Audio Players & Recorders
E280 and my computer do not connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 03, 2007 | SanDisk Sansa E280 MP3 Player
When i plug in my sansa e280 it shows the booting screen turns white, and boots again
It sounds like you have a virus or some sort in it. If you still have a warranty send it back in and get a new one. It sounds like you have been doing exactly what you are supposed to be doing. The only thing that I could think of is that it is the motherboard. that is going to cost you about $91 Thank you, Connie
Jun 24, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
91 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Sanath Kumar V
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
