I attached all the cords to the flat screen from the computer the monitor says test good but the screen picture does not come on how do i get it to come on
    Problem Solver:
  • 16 Answers
Having a guess at your problem I would say that if you bought yourself a new monitor and attached all the cables (2) correctly, then the issue here would be updating the drivers of your graphics card for that type of monitor.
Posted on Sep 03, 2008
Why seiki 40 inch has gray screen no picture but has sound
It's possible the Monitor has failed, but here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | SEIKI Digital SE40FH03 40-Inch 1080p 60Hz...
Cant find where to plug in power cords for emachines monitor screen E15T3r model 568
AC Adapter For eMachines E15T3r 568 LCD Monitor Charger Power Supply...
As you can see from the picture the power plug is a small round connector similar to an audio input. Power Connectors
look for a connector like the DC socket in the picture
Mar 25, 2014 | MPC Computers MPC F1760I 17" FLAT PANEL...
Monitor SAMSUNG 961BF does not turn on no picture?
  1. Verify that the power cord and Monitor cable are securely connected and not damaged. Unplug and replug these cords back in and test functionality.
  2. If the monitor still ceases to function, you may have a bad board, lcd screen, or inverter.
  3. I recommend replacing the monitor unless you are familiar with testing and replacing electronic boards and LCD screens.
Sep 12, 2011 | Samsung SyncMaster 961BF 19 inch Monitor
TFT8000 18.1 in. Flat Panel LCD Monitor: Was given the monitor with only a video cord. Pow...
It may have failed Backlight inverter circuits. You just need power AC cord and the VGA cable to attach to the PC VIDEO card. Try it on another PC.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Compaq TFT8000 18.1" Flat Panel LCD...
ViewSonic VA720 monitor will not turn on just a blinking light.
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
Jan 17, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
LCD monitor (viewsonic va720) "No signal"
Jan 05, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen is black and on button flases on and off
First check that your computer and your monitor are connected securely with a monitor cord (you always start at the physical) Try replacing the cord from the monitor to the computer first....if that fails its your processor in the computer that manages picture transfer...orrrrr....the power board modulators. One could be fried...I would check with an expert repair person before effecting any sort of repair.
Dec 15, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Do not know what plug ins to attach to computer I have power to the screen and it is on screen saver. I do not know what screen cords and attachments to use? None of the usual printer cords fit the back of...
It's very likely what you call the flat plug is the video cable. (Picture #1) below. The corresponding cable looks like (Picture #2). The other cable (A/C) by elimination plugs into an electrical outlet. Are you seeing a cable other then this one coming out of the back of monitor? d82bfa4.jpg697a779.jpg
Nov 29, 2009 | Mitsubishi Diamond Pro 91TXM 21" CRT...
Monitor only power's on NO sound and No Picture
check your cable to speaker of your monitor and to the audio output of your pc.
May 20, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Computer not recognizing moniter
Resolution set too high for display.
Attach TUBE monitor, Start Windows, change resolution to 1024x768 (MAX) and then hit APPLY/OK.
Also check refresh rate, it is listed in hertz (hz) in advanced settings. Should be 70-72khz not faster than either.
Shut down PC, Connect LCD, you should have a decent picture.
Dec 13, 2007 | Microtek C593 15" Flat Panel LCD Monitor
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
