Question about Olympus Stylus 720 SW Digital Camera
Battery life for my camera is miserable - I've had the camera for 2 years and I'm already on my second battery. Is this a function of the make and model or do I have a faulty camera? Thank you
  • 2,794 Answers
Usually Olympus cameras have other batteries with longer life in them. You just have to pay more for them.
How are the contacts in your camera? are they bent to the point that they could be losing contact or is there any corriosion or oxidation to them?
Posted on Sep 03, 2008
    President:
  • 1,263 Answers
It depends on what kind of battery your using. is nickel cadium or is a lithium battery there is a big difference. everything that uses a battery when in operation draws down a battery. is it rechargable? if so it could be your a/c charger is faulty and when charging the battery it's not giving it it's full charge. are you letting it fully go dead and then recharging? or are you recharging it constantly? these could be a few reasons other than the camera for poor battery life. but if a battery lasts a year i would say that it's a pretty good . hope this helps you.....please rate this
  • 6,487 Answers
That is not good, by the way is there a possibility that the battery is over charge? because overcharging it will cause some damage on the battery and it will only good for a few months...
Hope that helps........
Very low battery life
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
Dec 27, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
The camera was dipped into water and it was not functioning right now.
It could already be dead, water and electricity don't mix, but you could try this.
Take out the battery (If anything like this ever happens again, camera, mobile phone, anything electrical, remove batteries immediately).
Put it in a dry warm place, airing cupboard, over a radiator (but not on) for a few days to dry out the circuits, then put the battery in and try again.
If it doesn't show any signs of life then, I'm afraid its had it. But if you've accidental damage cover on your home insurance, you should be able to claim against that for a new one.
Apr 14, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
I am in Pune 411004 in India and have purchased Samsung digital es 15 camera recently. Original 2 aa Alkaline batteries have been completely used up.when I replaced these with 2 new eveready batteries...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Cameras
The battery life of my ku990 is abnormal
The two main causes of battery life loss that no one thinks of are:
backlight settings (if you don't really need the backlight to stay on for 60 seconds after the last button press, lower it. this is a huge waste of battery life and it is easily changed in the settings menu of nearly every phone i have seen)
poor signal areas (when you have low signal, you phone wastes its battery life searching for acquirable signal. if it is unable to locate the signal, it will continue to search. this search uses up your battery life quite rapidly)
Jan 02, 2010 | LG KU990 Viewty
My camera just does not seem to hold a good battery charge. I use fully charged batteries and this also happens with Duarcell too. I am only using the camera in the "on" selection.
Some digital camera **** the life out of batteries, especially the older ones, even when off. It stores info like date and time etc. I take the batteries out when I am not using it for a while. True it is a pain resetting the time but it saves the batteries. Also go for the top line rechargebles,
Oct 30, 2009 | Kodak EasyShare C875 Digital Camera
Short Battery Life
just today figured out that the battery supposed to be at least 17 hours and i bought it before 2 years too and even when i bought it was my battery left only for 2 hours and until today i thought it is supposed to be like that.
Jan 10, 2008 | Sony NW-A1000 MP3 Player
Hp rx1950 battery life.
I have the same problem, after I did the hard reset and installed no programs, this power problem disappeared. But once i installed any programs, PDA battery life became no longer than 2 days, which is strange.
Jan 06, 2008 | HP iPAQ rx1950 Pocket PC
ERROR C-2
Try replacing the battery - if it too is five years old, it's probably worn out.
Jun 24, 2017 | Konica Revio KD-300Z Digital Camera
Olympus Stylus 720 SW Digital Camera Logo
57 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
