Question about Dewalt 18 Volt Compact Drill Kit
Problem with the chuck
When i go to screw something in its fine but when i hit reverse then the chuck relases bit or whatever is in it.
can't remove a chuck case there is no bolt in it
it is a dewalt 18v hammer drill
  • samritchie69 Nov 02, 2008
    I have the same problem with my dc925 ... thought I would take out the chuck to clean it and lubricate it but cant get it out ?
Had the same problem on mine. Remove the chuck, then remove the snap ring on the back of the chuck( carefull, the housing will fall out once the ring is removed), on the side of the chuck you'll find a cam and small odd shaped spring held in by two cylender pins, on mine the spring had a gap in it and I just spread the gap to about twice the size in was and put everything back together and it has worked fine ever sence. Hope it works for you.
Posted on Dec 16, 2009
    Champion:
  • 313 Answers
R u talking dc925 model. if it's under warranty.have them replace at the service center.
Posted on Sep 05, 2008
How to remove keyless chuck
open the chuck jaws right up
down the center of the chuck you will see either a philips screw head or a hex head for allen key
hold the shaft at the base of the chuck to stop it from turning and undo the screw in the chuck in a right hand direction ( it is a left hand thread) when you have that out , still holding the shaft turn the chuck in the left hand direction ( normal thread ) and screw the chuck off
to assist in undoing the chuck do it up so that the jaws come out a bit
place something between the 3 jaws to act as a lever or use an allen key in the chuck done it tight and use that as a lever to undo the chuck
the secret is the lh thread screw in side the chuck which stops it from undoing when the drill is in reverse
Nov 17, 2015 | Bosch 18V Brute Tough Drill with Blue Core...
How do I remove chuck
or if there is no screw in bottom,then it is a screw on chuck. put chuck bit into chuck as if you were tightening it, then hit it with a mallet to remove(counterclockwise)
Oct 21, 2015 | Drills
How to remove chuck
if it is a reversible drill , open the chuck jaws open all the way and at the bottom of the chuck inside you will find either a phillips screw or a allen key screw
turn that screw in a clockwise direction as it is a lh thread and is a locking screw to stop the chuck coming off when used in reverse mode
hold the shaft at the base of the chuck and using something like vice grips on the chuck( section in from of the key teeth) grip firmly and hit hard with a hammer on the grips to undo normally
Sep 17, 2015 | Drills
When in reverse chuck will not stay tight. (when removing screws or whatever chuck will loosen and let bit fall out)
I would start out blowing out the chuck with high pressure air because you might have some saw dust or other item causing friction that is allowing the chuck to move. Then I would spray a lot of WD-40 down the chuck to float any contaiminents up.
Jul 06, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My 18 volt dewalt cordless runs well except when I try to remove something with it. Reversing the drill makes my nutdriver bit fall out as it opens the chuck, so all removals have to be done by hand.
I would make sure that the bit is firmly installed in the chuck, you should hear clicking when the bit is tightening, this is the chuck locking itself on the but. and when going in reverse make sure you dont have your hand or have the chuck pressed against an object. If nether of these are the problem then there may be a problem with the chuck itself and should be replaced.
Apr 02, 2011 | Dewalt 18 Volt Compact Drill Kit
Need to know when removing a chuck from a drill is it clockwise or counterclockwise?
The retaining screw at the bottom of the chuck ( down inside where you put the drill bit) is reverse thread. the chuck itself is regular thread. Take out the retaining screw, chuck a 3/8 inch allen wrench ( short side) into the chuck just like a drill bit. Lay the drill down on a work bench with the chuck pointing towards you and the allen wrench clear of the table. Hit the allen wrench with a hammer, ( may take a few tries) in a counter clockwise direction. the chuck should unscrew.
Nov 17, 2010 | Milwaukee Tool Drills
Need to replace the chuck on a Bosch 1194 VSR Model number 0 601 194 739
open the jaws of the chuck up all the way. There is a retaining screw at the bottom ( under where the drill bit would go). this screw is reverse thread. once the screw is out, get a 3/8 inch allen wrench. chuck the short end into the drill chuck. set the drill on a workbench with the chuck hanging off the edge a bit. Hit down on the allen wrench with a hammer ( counter clockwise) and the chuck will unscrew normal thread.
Oct 21, 2010 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
How do you relase a drill bit from the chuck on a Dewalt cordless drill
opposite of the way you put it in. Grip the chuck and put the drill in reverse and turn the chuck. or hold on tight and pull the trigger.
Jun 07, 2009 | Dewalt 18 Volt Compact Drill Kit
Keyless Chuck releases bit when reversed
hi
open the chuck all the way and then look down in the centre of the chuck you should see a cross head screw
unscrew and the chuck should pull out as this is on a taper system ( note the screw is left hand thread )
Nov 21, 2017 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
542 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
