Question about Casio LK30 Note Lighted Keyboard
CT731 keyboard wont read floppy disks lately - Casio LK30 Note Lighted Keyboard
  • breezamel Sep 04, 2008
    it used to but recently has progressively started not reading floppys
  • jordan king
    jordan king May 11, 2010
    does the keyboard read the floppys??
  • 66 Answers
Try getting a cleaning floppy disk  (the head might be dirty)
hope this helps
Posted on Sep 05, 2008
Sy85 floppy drive
It could possibly be the drive belt on your disc drive. The original drive used on the keyboard was not direct drive, over a period of time the belt wears and either slips or perishes. You might think it is still working as the motor spins and sounds as if there is life.
Take the drive out and look under the drive to see if belt is there if not replace.
Belt should go around black disc and brass capstan.
Apr 04, 2014 | Yamaha Music
Unformat floppy disk emulator
Your questions,what does it mean?
If you use PA50SD,of course you don't need floppy emulator.
If you use PA50 with floppy emulator,you need to format the flashdisk with special softwares (SFD 1.23 etc) that usually included when you buy the emulator.
Jan 19, 2014 | Korg Pa50 Professional Arranger Keyboard...
Unformat floppydisk emulator
Floppy emulator can't read flashdisk untill it formatted.
Flashdisk MUST BE format by special softwares.
Install the softwares on the PC/notebook.
No matter how much flashdisk capacity,floppy emulator will continue to read as one 1.44MB floppy.
Through special softwares formater, we can determine how many floppy that we will create. Lets say,100 floppy (or more),softwares will format the floppy 1.44 100 times on the flashdisk.
So we have 100 pieces 1.44MB floppy inside flashdisk. If one floppy can store about 30 MIDI songs,then it means that we already have 3000 songs in flashdisk.
If you format for 100 floppy,the total capacity of about 144MB.
So,flashdisk with a 2GB capacity, is more than enough to store songs.
To change from one floppy to enother,just press bank number at floppy emulator panel.
I hope this helps.
Jan 17, 2014 | Korg Pa50 Professional Arranger Keyboard...
I own a Korg Triton Classic. I just replaced the touch screen on it. Now it wont read the floppy disks...any suggestions
It is VERY easy to not have gotten the cables back and seated completely for the floppy disk. ALSO it is very easy to damage the ribbon cables on floppy drives by pulling at the edges of the ribbon to pull connectors off. One MUST distrbute the force all across the cable as it is easy o damage the connections in the connector for the wires near the edge. It is also easy to damage the pins on floppy drive connectors. You will need to reopen the unit and check the cables INCLUDING the little power cable to the drive. If you have damaged the ribbon cable you can either replace it or possibly get another connector and put it on the cable right next to the one with the problem and crimp it in a vise... These are an insulation displacement type so you need to get it on straight and ALSO verify the index is the right direction before crimping. For your problem think cables, cables, cables...
Jan 26, 2011 | Music
The disk drive on my Yamaha Clavinova CVP-105 acts like it has a disk in it when it doesn't and won't always play pre-formated disks like it used to. Is the drive dieing? Where can I go to get it fixed? ...
Often these drives are continuosly selected by the controller and rotate even without a disk.
These USUALLY use the old 720K disks which are almost impossible to find. The common 3.5 1.44Mb floppies often will not work in these units.
You can SOMETIMES use the 1.44Mb disks by covering the second corner hole AND degaussing the disk with a tape eraser and then reformating the disk in the Clavinova.
The pre-formatted 1.44Mb disks without degaussing SOMETIMES leaves artifacts between the tracks used by the 720K disks that causes problems.
Nov 27, 2010 | Yamaha Music
When I load a floppy with music styles into the
Not sure about your particular keyboard, but on the Yamaha Tyros the style will NOT start rhythm until you select start AND hit a chord.
The style doesn't know what chord to start with until you trigger it.
SOMETIMES the style has to be moved to a user space...
One has to read and then DECYPHIER how to work these synths... Spend a little time with the user manual, as hard as it is to understand.
Jan 12, 2010 | Yamaha Music
How do i edit and store midi files on my tyros keyboard.
Storing is easy... editing is NOT so easy and is better done using a PC with an editing program.
Not knowing which model Tyros you have, either bring the MIDI files on floppy disk or USB stick.
Select the floppy or the USB source on the Tyros while in the song mode. Find and COPY a file or files, then move back to the place you want to store them like hardrive or user space and PASTE. You can create folders before each to keep the things seperate.
Oct 28, 2009 | Yamaha Full-Size Keyboard
I am trying to load the new OS for the triton studio. My studio says i need sysyem 1 disk. I don,t have it. Solutions?
They need to be downloaded from You need to have a floppy disk drive to load them unfortunately.
Jul 14, 2009 | Korg Music
Not reading my floppy disk( MPC 2000xl by akai)
Have you tried formatting the disc using your MPC 200XL?
Mar 20, 2009 | Music
Floppy disk drive
It needs no further fixing now.
I rebooted the keyboard as suggested by the FAQ then reformatted the floppy in the computer. I tried a recording which it then played back fine. It also acknowledged the title of the song as 001song as normal.
Thanks for the chance to air the problem though.
Nov 09, 2008 | Yamaha Portable Keyboard with 61...
Music Logo
59 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
