Question about Belkin (F5D7230-4) Router (587009)
Hi can i ask?
What is default IP belkin how can i get my IP no.???
  • 928 Answers
Normally the default IP of the Belkin router series is 192.168.2.1 but to find out what is on your Belkin it would be easier to connect your computer to it via wired or wireless then.
Click start then run then type in CMD then hit ok
In the Command Window type in IPCONFIG
the IP address isthe IP of your computer
The gateway is the IP of your router.
If you need further help just respond back
Posted on Sep 03, 2008
  • Belkin Master
  • 6,487 Answers
By default the ip address should be set to 192.168.2.1
You can also get the defaul IP by doing IPCONFIG on the command prompt that's the deafult gateway..
Hope that helps............
What Is the Default IP Address of Belkin Router? And determine Admin password?
HI ! HERE YOU GO!
https://www.lifewire.com/what-is-the-default-ip-address-of-a-belkin-router-818062
How to Find the Default IP Address of Belkin Router
Oct 24, 2017 | Belkin Computers & Internet
F5D7234-4v3 Belkin Router I have the above listed
Press RESET button for 10 seconds it is in back side of router. Then all settings defaults. Then you can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Sep 22, 2010 | Belkin Computers & Internet
Installation of belkin router failed
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
May 08, 2010 | Belkin (F5D5231-4) Router
IP conflicts using the Belkin Model 570230-4 router and I do not have the belkin utility CD.
For that you need to enable dhcp on router.
Then set in your computer network adapter property to ip get automatic.
For belkin router http://192.168.15.1
or
http://192.168.2.1
Then enable dhcp and save settings and restart router.
Feb 07, 2010 | Belkin Computers & Internet
Unable to get the managment page on belkin wirless g plus mimo router. before it was working on the ip address 172.16.18.xxx but now its not openning managment page at all, can i see someanother way what...
or
http://192.168.2.1
Feb 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
MY BELKIN ROUTER IS ASKING ME FOR A PASSWORD I DON'T HAVE. I NEVER SET A PASSWORD, THAT'S WHY I CAN'T FIGURE IT OUT
You can secure your wireless network wit WEP or WAP code.
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Jan 31, 2010 | Belkin (F6D3230-4) Router (F6D32304)
Hi i cant get ip on my belkin f6d4230-4v1 can you help?
Actually for the Belkin F6D4230 the default IP is 102.168.2.1
Oct 10, 2009 | Computers & Internet
BelkinMIMO wireless router stopped connecting to internet
I just installed a Belkin N1 (model F5D8635-4 v1000) to a Comcast Arris modem in SW Florida by resetting the IP on the router to 192.168.1.1 Comcast assigns 198.168.0.1 (but will accept 192.168.1.1 however not .2.1) and Belkin default is 192.168.2.1. Problem is easy enough to correct by following the instructions for changing the default router IP using a Firefox interface as documented in the user's manual. Note that when applying changes it takes about 30 seconds for changes to be effective.
Sep 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin (F5D7230-4) Router (587009) Logo
192 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
