I had this same problem and replace the projection bulb and it works fine now. Bulb is available on-line (google the brand and model number and you should get multiple places to buy it from. For the RU-52SZ30 model I have the replacement bulb part number was 6912V00006C. The bulb can be accessed from the back with a phillips screwdriver and a module holding the bulb can be removed pretty easily. The bulb is held in place by a wire and connected to two wires that need to be lossened with a screwdriver and small wrench (pretty obvious when you remove the module). For less than $200 this should fix the problem. I paid the local TV repair guy $100 to come out and show me. He was honest and said I would be better off getting the part over the internet and replacing it myself. So maybe you can save the $100+ and replace the bulb yourself. He did say that the bulbs typically last 2-3 years before needing replacement.
I have a 52" LG Prjection TV model number RU52SZ30 and it turns off after 45 seconds, also the blinking lights flickers on the lamp. What should I do first replace the lamp or reset the tv and how can I reset my TV. If a lamp problem where can I purchase one and how much and if I buy a lamp and I still have the same problem what do I do now.
Thanks.
