Question about Water Heaters
Water heater i have a 1987 alpha gold and i am having trouble turning on the water heater how do i do it
    President:
  • 1,263 Answers
Is it natural gas/propane/or electric?
Posted on Sep 03, 2008
I had an issue with turning off the fill valve on my alpha boiler and the pressure went to 1.5 bar when cold and rises to 2.75 when the heating comes on is this ok.
You need to check with the boiler/system specifications to discover the correct pressure.
An overpressure condition should be dealt with by a safety valve that usually vents to the outside of the building - if it is working correctly. There have been incidents of this external vent freezing causing dangerous pressure to build in the system. I understand a modification is simple and inexpensive but I don't know any details.
Our pressurised system runs at about 2.5 bar hot, or at least it used to do when it was younger...
Jan 25, 2017 | Water Water Heaters
Electronic panel of my Alpha Water Heater is burnt out
Would not of thought so, even if it heats up the water, no control, So ultimately not going to be safe, replace the board
Mar 04, 2013 | Water Heaters
GE water heater Model # GG38T06AXK00 pilot will not light
We are a local plumbing and drain service that sees these types of failures on these types of water heaters all the time. Call us today for your free in home Estimate. We are affordable, & offer same day services.
(Let us know where you found us for your Discounts)
Alpha Omega Discount Plumbing & Drain Services 661-836-8813 Bakersfield, 661889-2625 after hours
Licensed #945568 BBB Accredited
Jan 12, 2012 | Water Heaters
"kenmore 153335450 not sure when
You have water visible on outside of tank?
TP temperature-pressure valve is probably releasing water.
http://waterheatertimer.org/Leaking-water-heater.html
Age of water heater is determined by alpha-numeric serial number on label on side of tank.
Look at second two digits: On older kenmore for example C05.., was made in 2005
Aug 23, 2011 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Hi im having trouble lighting my water heater and turn the water to hot. it says push and hold the knob and repeatedly press until pilot ignites.
after pilot lite you got to hold it down for 45 sec before you can turn it on..if you still having trouble get a qualify technician to relite it.
Aug 09, 2010 | Honeywell Water Heaters
Where do I find the rheem alpha drain valve
Go to homedepot/lowes/ace and get a brass 3/4 long stem hose bib.Abanodon plastic is useless.
Mar 19, 2010 | Rheem Water Heater Drain Valve
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Lack of hot water from water heater
Unit needs a new "dip tube" It is cracked and allowing cold in water to mix with all hot water resulting in "lukewarm water". Need plumbing skills to change out at cold inlet top of heater,pull out old,buy new at hdepot 5.99 reinstall.
This has been a small manufactor recall on this matter
Please rate Thanks
jj505
Mar 29, 2009 | Whirlpool Water Heaters
Water Heaters Logo
70 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
