Question about Technics SUV500 2-Channel Amplifier
STK Problem... I would like to know What Genuine STK is used in this Amplifier
    Genius:
  • 1,239 Answers
Hi sir.
please follow the link.http://www.audiokarma.org/forums/archive/index.php/t-16334.html thnk's sir.. please rate it.
Posted on Sep 03, 2008
Front left channel on FISHER tad-9925 broken
Chances are that all you have to do is replace STK 411-230E.
Jul 10, 2017 | Fisher Audio Players & Recorders
STK 8170
Have had a good look on the net and no STK 8170! Except your post on Fixya!! Which is odd. So I'm thinking you might have read the number wrong.
Jun 29, 2012 | Audio Players & Recorders
Convergance chip
devices: Any Projection TV with a Convergence Amp board
If I knew which Mitsubishi Projection TV you're looking at, I could help quite a bit more. In general, the "convergence chips" on a typical Convergence Amplifier board are actually two STK's mounted to large heat sinks. "STK" is electrical engineering slang for "Convergence Amplifier Integrated Circuit".
Here's a helpful Solution archived at FixYa:
http://www.fixya.com/support/t4337218-image_bowed_line
You'll see in the photo that the STK on the PC board actually have part numbers on them that begin with "STK".
Dec 09, 2011 | Mitsubishi Televison & Video
Dead Mitsubishi WT42313
hello when you changed the stk are there any resistors near by if so these need to be tested aswell also any capacitor near by these need to be tested desolder 1 end so you get a good reading on the meter i think the resistor are 39 ohms good luck
shaun
Nov 05, 2009 | Televison & Video
What is STK ICs?
STK-series integrated circuits are amplifier IC's that are most often used in projection TV sets as convergence output amplifiers. When these or other convergence parts fail, the three color images no longer line up correctly on the screen.
Jun 17, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Need more help on stk-392-110
Possible cause if generic chips were used. You can't use generic STK chips on this set they will blow, if not right away most likely within a month. I just did my friends set and spent 51.00 a piece for genuine Panasonic STK chips, didn't replace any other components and its fine. (I did have an unrelated issue with fluid but the set is fine now) I am not sure that is the problem your having but if you got cheap chips in the kit you bought, there is a chance they blew again. Also double check your solder connections make sure there isn't any bridging or cold solder joints. Did you use new heat sink grease (white paste)? Checking the voltage is good advice also. My advice is based on the assumption that you tried to fix the convergence through the convergence menu on the set and still couldn't get it. Let me know...
Mar 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Dec 20, 2007 | Pioneer VSX-816-K/S Receiver
Technics SUV500 2-Channel Amplifier Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
