Question about Maytag Atlantis MDE6400AY Electric Dryer
Clunking maytag dryer
I can't get to the back of my dryer due to a casted broken leg.
I have a Maytag Atlantis electric dryer purchased at Best Buy and delivered on 16 October, 2003. I don't remember it being the highest-line model they carried. I think Best Buy may have had their own specific model numbers, but I'm not sure. The delivery service botched the vent connection badly and I had to revise it, but other than that it has worked well. We average about one heavy load a day.
About a week ago I noticed a cyclical clunking sound while the machine was running. I thought at first of a knot of tangled clothes banging around, but when I pulled the clothes out there were no tangles. I restarted it empty and the clunk was still there. It clunks at about the same point of each revolution of the drum.
As I said, I'm a bit incapacitated right now, but any suggestions will be pursued as soon as I can.
  • 550 Answers
The machine is opened and inspected from the front
opening from the front there is no heavy lifting or moving of the dryer needed,
the usual causes of a ' cyclic clunk '
a worn spot on a drum felt. when that area reaches the bottom, the weight of the
drum causes a clunk.
a damaged belt that clunks when the tear hits the drum
a collapsing drum roller(replace in pairs)
each is easy to fix, cheap,
Posted on Oct 13, 2008
Need to know the correct 3 prong power supply cord to use for a Maytag Atlantis dryer.
Hi fredmcmur227...
There are many different pattern plugs and recepticals.
It is impossible to tell you which power cord to buy.
What you will need to do is find out what the receptical for the dryer looks like and match the receptical with the power plug your going to purchase.
I will also include a link to show you how to hook up a 3 prong wire power plug.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jul 11, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer all the sudden will not turn on or make any noise.
I suspect the door safety switch is broken. If not check one, some dryers have two, high limits. These are safety switches that keep the tumbler from spinning when door opened, and prevent the dryer from overheating
Feb 01, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
We have a Maytag Atlantis dryer. Inside the tub
Did you try opening up the back of dryer or the top?
Sep 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Clunking sound on dryer
Remove the front panel and check the blower wheel attached to the motor.
It may need replacing.
Possibly lint and debris blocking it.
Feb 21, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Replacing Timer on Maytag Atlantis Dryer
Call a local appliance shop and ask about it. Maytag is pretty common and available. The timer will be about 75 dollars. It could be more depending on what all you have on it. It is pretty easy to replace once you get to it. Let me know how this turns out.
Jan 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag electric dryer will not run
belt around the drum is broken. The light you see is the glow of the heating element. No air flow will cause heater to get red hot. Danger!
Dec 03, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis Dryer not heating up
Best guess is that one of the two solenoid coils on the gas valve is faulty, one has two connections and the other has three. Always replace BOTH solenoids even if only one has failed.
Aug 10, 2017 | Maytag Atlantis MDE7400AY Electric Dryer
Doesn't heat and dryer light no longer works
make sure you have power to BOTH legs of the 220v.
Feb 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
173 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
