Fisher and Paykel IWL12 Top Load Washer
Problem for Fisher and Paykel IWL12 Top Load Washer
Fisher & paykel top load washing machine
By 4steelerfans on Sep 03, 2008
My machine gets to the spin rinse cycle and the machine starts to beep. It does not drain and will not spin. Any step by step directions to try and fix the problem would be appreciated. Thanks.
Best Solution
posted on Oct 21, 2008
Helpful)
HiRoller
Rank: Master
Rating: 82%, 17 votes
check my issue "eco smart won't drain, smells hot" on how to remove the motor unit from bottom of machine. I had a sock down in the lowest part of the drain area that I couldn't see from above between the outer/inner tubs. Mine finally burned out the motor so I had to remove it. That motor unit unclips from machine--like a childproof cab, lift tab with finger and twist unit off. Quarter sized hole into tub is where i found the sock.
Was this helpful?
Yes
No
Solution #2
posted on Nov 07, 2008
Somewhat Helpful)
gryshrncrcsy
Rank: Apprentice
Rating: 75%, 1 votes
We had the same problem with our washing machine being full of water and beeping during the rinse cycle. The problem is that the filter, which is located under the washing machine, is plugged with something. Ours was plugged with a cotton swab. You have to tip the washing machine up and remove the filter and unplug it. The filter is in the center of the bottom of the machine. It twists off. I had to get the cotton swab out of inside the machine through this opening.
This machine plugs up a lot - I've never experience this with any other washing machine. Good Luck!
Was this helpful?
Yes
No
Solution #3
posted on Oct 25, 2009
Not Rated)
suze
Rank: Apprentice
Rating: 0%, 0 votes
I have a Intuitive IW812. When it is at the spray rinse cycle, no action is happening (no spraying of water). It then beeps with code 37. I stop the machine - turn on again and fast forward it to Rinse 2. It completes the full cycle and turns off but majority of time it hasn't spun it fully and sometimes there are suds amongst the clothing on the bottom. There is also some dirt/grit within the clothes.
Was this helpful?
Yes
No
Popular Solutions for Fisher and Paykel IWL12 Top
Questions and Unsolved Problems for Fisher and Paykel IWL12 Top
Do you recommend Fisher and Paykel IWL12 Top Load Washer?
Answer
Answer
in spin cycle it bangs as it spins. i rearrange the clothes inside bt it still bangs. if i take... (More)
Answer
water take long to fill and rinse and make a noise during process
Answer
have water temperature set at hot. When water starts to fill, it is hot but changes to all cold
Answer
The Iwl 12 washer has a error 37 code, and the agitator fin has broken off
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fisher and Paykel IWL12 Top...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14909
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
